Gaming laptop £2000 temps are key
12 Mar 2015
Currently looking into getting a Gaming laptop and was wondering which manufacturers are well known for the better cooling systems so you can get the performamce you would expect spending the above amount.
I would suggest looking at Alienware laptops, they’re a bit larger and heavier as a consequence. But I’d recommend based upon my experience with the 15” Nvidia 1070 laptop.
Thank you can you give me any idea of temps cpu gpu wise on triple A games today. Bfv for instance if you play it. I was thinking about an RTX laptop but looking at benchmarks I think the only one to go for would be a 2060 version which is on par with a GTX1070 judging by the reviews I've seen so it's one or the other going to see if the price drops on the GTX1070 versions.
I haven't tested my actual machine but if I recall correctly, this was the video that helped me make my mind up.
i can highly recomment the Acer Helios 500 laptops the cooling on these things are insane.
With Max fan speed on you can actually feel the movement of air around your arms, playing BF5 if i turn on the fans to max the system temp goes down to 31C / GPU 47 / CPU 49 (Acer Predator SeNSE) (Ryzen 7 2700 & Vega 56 spec laptop)
But to be honest i lease the system on auto and most ofthetime you never hear the fans spin up most of the time.
