Dear god. I can guess the answer, but is any of this stuff recyclable?
Mine worked fine fine off the bat though if you google around there are recommended upgrades to buy fairly cheap such as a new bowden tube(recommended, i bought just cheap ptfe tube off ebay and it was an improvement) and a lot of usefull extras you can print off for it. If you want to print over usb download repetier host and if you want to print from sd cardss(best method) download a slicer like CURA).
No, i print mine and throw it directly into the sea.
I'll take your avoidance to form an adult answer as a no they're not recyclable, as I thought.
Isn't it pretty obvious that it is recyclable? It's literally and visibly a material designed to be heated up so it can be formed into a new shape.I'll take your avoidance to form an adult answer as a no they're not recyclable, as I thought.
Very nice work.
Have they made 3D printers yet that can print without the "layered" look? I know it is laid down in layers so hard to avoid but would sanding finely down or applying heat even out the finish?
Depends on the filament a bit - some the layers are very obvious others less so - I have some fake marble stuff (I think it is PETG but not 100% on that) where the layers are almost invisible. You can use various processes to smooth it up a common one IIRC uses an acetone vapour bath but very easy to overdo and spoil the print if you aren't careful.
On some prints I lightly sand and use a primer and a couple of other finishes to smooth it out.
Also how fine you print will make a difference - some of the pictures above look like they've been done at 0.15-0.2mm - 0.06-0.1mm will help to minimise the striations - but takes a lot of time and more filament and especially on bigger models.
Very interesting, thanks for the reply.
I'm sure it won't be long until you can't even tell that it has been 3D printed.
Came out rather well.
