Does Intel lies about chipset support?
22 Nov 2009
Under the hot sun.
Here is an interesting video by Linus
Even if according to Intel, 8th series chipsets aren't backwards compatible they are testing a H310 board, with both 8700K & 7700K using DDR3 (yes 3) RAM the board supports. (it also supports 6x00 series).
And apparently there is a newer revision of this H310 board, which is supporting 9X00 series also.
Intel lies!!!! shock
If Intel wanted to they could make their chipsets much more future proof on the other hand just because something supports something as per the video it doesn't mean the support is robust and/or that all features are perfectly possible to do under that chipset as per the end of the video where it might not pass quality control standards even though it works.
