Caporegime
Liquid clay
https://www.amazon.co.uk/dp/B079QM2...=9044975&hvtargid=pla-477194406875&th=1&psc=1
Anyone tried it? Seems to have good reviews.
That's just a standard fallout remover. Similar to ironout or ferrous dueller
Liquid clay
@kindai is snow foam okay on convertibles, i've only ever hand washed my boxster as i didn't want to remove any water repellent from the canvas?
chemical guys maxi suds is good and thick...but its also a bit about the lanceDoesn't look like it is.
I might try the Adams Polishes or Chemical guys snow foam.
I used the Gyeon Foam recently but it was expensive and it didn't work as well as I thought it would for the price. Maybe I wasn't using enough.
autobrite lance has been excellent...the stuff thats gets bundled with pressure washers is usually rubbish
I’ve ordered some of the cherry flavour Maxi Suds II and a 1.1mm orifice for the foam cannon. I’m using a $20 foam cannon so maybe that’s why I’m not seeing good results.chemical guys maxi suds is good and thick...but its also a bit about the lance
Different pressure washers use different attachments, but the lances are generic (they just need the right adaptor). I'd recommend a Nilfisk of some sort. Much cheaper than Karcher but don't seem any less good in my experience. It will require a new adaptor on the snowfoam lance.I’ve just had gen-3 glasscoat applied to my my has anyone had any experiences with it?
Anyway my trusty karchar has sprung a leak can anyone recommend a decent pressure washer that I could use along side with magifoam with lance or does the magifoam lance fit all pressure washers?
I ask because I’ve been recommended to use the gen-3 shampoo which is £13 for a small bottle.
Has anyone tried Gyeon Q2M Wet Coat?
I have washed the car tonight, sprayed this on and I am amazed. It seems to have provided amazing protection for such little effort (spray on + rinse off). Better than a spray wax or even a paste wax it would seem.
I’m more curious to how it works more than anything.
Will be interesting to see how long it lasts.
Gyeon products in general are the best out there by miles IMO. Their foam is just amazing.
Bathe+ as a shampoo, leaves a good hydrophobic coating on there that lasts a week or so.
Wet Coat is just something else though. As you say, so easy to apply (although I do a quick spread of it with a detailing mit before rinsing it off). Much better than the other sprays I’ve used.
I switched to Wet Coat Essence which is a concentrated version of it, which you dilute yourself. A strong mix of that will last a good few months.
I bought bathe+ too, and agree it leaves a hydrophobic coating.
However the suds didn't really transfer to the wash mitt despite the bucket appearing to have plenty of suds. A little off putting...though I know suds don't make a great shampoo. Maybe I didn't use enough of it.
EDIT: @Raymond Lin rinse with a pressure washer (it said this on the bottle).
Okay, thanks, but the idea is just spray this all over, then rinse it off?
Like, totally no need to touch it?
