- 30 Mar 2017
Some updated figures regarding the silicon lottery.
Keep in mind their sample size and that it may not represent your own chances when buying a 9900k.
I think this is useful info for those overclocking. No info yet on why those particular voltages were chosen or any temperature data.
Bins are created for stability in nearly every workload and tested using a 240AIO. These percentages can be considered accurate, conservative or optimistic depending on your own expected use and cooling.
As of 2/6/19, 100% (no change) of tested 9900Ks were able to hit 4.8GHz or greater.
- CPU Multiplier: 48
- BCLK: 100.0
- CPU Vcore: 1.275V
- AVX Offset: 2
As of 2/6/19, the top 86% (+1%) of tested 9900Ks were able to hit 4.9GHz or greater.
- CPU Multiplier: 49
- BCLK: 100.0
- CPU Vcore: 1.287V
- AVX Offset: 2
As of 2/6/19, the top 39% (-2%) of tested 9900Ks were able to hit 5.0GHz or greater.
- CPU Multiplier: 50
- BCLK: 100.0
- CPU Vcore: 1.300V
- AVX Offset: 2
As of 2/6/19, the top 8% (-3%) of tested 9900Ks were able to hit 5.1GHz or greater.
- CPU Multiplier: 51
- BCLK: 100.0
- CPU Vcore: 1.312V
- AVX Offset: 2
As their sample size increases both 5.0GHz and 5.1GHz samples again show a drop making them even rarer while 4.9GHz has become slightly more common.
A bin for 5.2GHz or higher is still noteably absent for the 9900k unlike the 9700k which had the 5.2GHz(10%) bin added at the end of last year/beginning of 2019.
This shows that silicon lottery is willing to update their bins when a new frequency becomes available in sufficient quantities, and that even with an AVX offset, 5.2GHz+ samples are in such short supply that there aren't enough that meet their criteria to be considered for sale as yet.
This mirrors the listings from both Caseking and OCUK that sell frequencies up to 5.1GHz with AVX offset but nothing higher.
I'm in the top 39%. I win 1 extra FPS! I'm just happy it's an even number at 5GHz. That annoyed me more than anything.
