Consensus on 9900k temps and cooling?
6 Feb 2019
Let me describe my predicament
I have a 8700k @ 5ghz, it requires 1.37v to be stable. Its on 360mm AIO with 6 fan push/pull.
It's not delid and I'm not going to. The CPU can spike up to 88c degrees observed so far in Summer
It seems reading around here, a lot of 9900k are getting 5ghz at 1.3v - and the 9900k has a better heatspreader - what sort of temps can be expected on a 360mm AIO @ 5ghz with the 9900k?
Thanks
16 Dec 2008
There's no guarantee a 9900k will even hit 5Ghz. Something like 40% are capable at 1.3v but the other 60% may not be capable even at 1.4v.
30 Aug 2018
It really depends on how high you need to push the vcore to get 5GHz. Some will do 5 at less than 1.2v which means a cooler running CPU, while others (as pointed out above) refuse to do 5GHz no matter how many volts you throw at them.
The 8700k was similar in this regard so whatever CPU you buy you are playing the odds of the silicon lottery when it comes to overclocking.
The solder TIM helps keep things cooler than the TIM used on the 8700k but you are still at the mercy of the quality of the silicon.
OP
6 Feb 2019
To ignore the lottery - let's assume I buy the 5ghz 1.3v 9900k from silicon lottery, it's on stock at the moment
I just want to know what temps to expect with a 360mm aio
30 Aug 2018
30 idle 50-60 gaming
Edit - by idle i mean light pc use. Browsing, netflix, that sort of thing. Thats just a rough idea and obviously ambient temps will raise or lower that.
16 Oct 2015
Norfolk, ENG
Thanks
at 100% load for over an hour in AIDA64 I get average temps 70/80 and max of 86/88c 1.38v to keep at that load.
Gaming takes max 1.315v and temps max out at 70/75 for over 4 hours of gaming. Average temps are low to mid 60s
28 Feb 2011
Norwich
this. I have one of the worst and to get 5 it needs 1.45 in it! It runs so damn hot with the h115i pro. heavy cpu intensive puts it upto 85c. prime95 small test throttles hard
but general gaming its at 70c
OP
6 Feb 2019
And yet that is still better than I get - my 8700k with 1.37v 5ghz hits 88c as soon as I run Cinebench, it takes 1 second to go from 25c to 88c
28 Sep 2018
I have a Dark Rock 4 (non pro) cooler with my 9900k at 1.26v @ 5ghz no AVX offset in a HAF X case which is great for GPU cooling but just "ok" for CPU cooling.
I have the fan at 100% on the cooler. Idle = 28-30c Regular gaming = 65-70c Battlefield 5 = 70c with occasional spike to 80c
An AIO should performance 7-10 degrees better at load than this.
9900k temps shoot up a lot with vcore. Example, same CPU with 1.30v will add another 5-7c.
