- 11 Sep 2013
NVM
Analysis Typical Value
Hardness Level Soft
Hardness Clark 2.63
Hardness French 3.76
Hardness German 2.11
You know why that chiller has UV built in? Because its activated carbon filters remove all the residual disinfectant (chlorine) which is what protects the domestic water supply. They then have to use UV to kill any bacteria that would grow in it using UV light. My question would be, what is the contact time of the water with the UV, because insufficient contact time will not kill all of the bacteria. Then you are effectively drinking pond water.
(Where I used to live it was 316 CaCOs mg)Virgin pure have an amazing customer …
Virgin pure have an amazing customer service. Georgina Simpson dealt with me and I couldn't have asked for a more friendly helpful person. She would be on my Christmas card list for sure. She sorted everything out for me and made me smile. I wouldn't go anywhere else now.
Their water machines are pretty good too
Water is barely purer than TAP WATER
I have been using the unit for nearly a year now, and I am very happy with the service. When we needed a new filter Virgin where compliant and helpful, and sent it out very quickly. We have never had any problems with its operation.
HOWEVER. It is a water filter, so the ultimate test of it's worth is in it's filtration capacity. When I tested the water from my Virgin Pure, it came in at a TDS rating of 274 ppm. To put this in context, the tap water in my area rates at about 310 - 320 ppm. It is barely more pure than TAP WATER!! Now to be totally fair to Virgin, a TDS meter does measure both minerals and contaminants. However, mineral water rates at between 50 - 100 ppm. So, unless Virgin are going to claim that their water contains 3X the healthy minerals of spring water, I think it is fair to say that the majority of these dissolved solids are unwanted contaminants. The water from the Virgin Pure is so far from Pure, I will not be continuing to use it. I DO NOT recommend this product.
I use a berkey water filter, I believe it's one of the only filters that filter out flouride.
I can tell the difference between tap water, filtered water and bottled water, can anyone else tell the difference? Or am I just weird?
we steam >95% of veg , so it wouldn't be immersed in questionable water.all our drinking water and veg water goes through it.
softeners though ? (what might you recommend?) - which is the main reason I'm in the game.Would I use a water filter? I dont think so.
If generally the water smells a little 'chlorine' like, that is just residual disinfectant that hasn't been used up (killing bugs) and generally occurs when a lot of water has been pushed through the mains. No odour generally means that the residual disinfectant has all been used up, the water has been sitting in the pipework a little longer. A diesel or TCP smell, is generally an indication that somewhere in the network there are old tar-lined pipes that the chlorine is reacting with and forms trichlorophenyls (TCP) which has a distinct odour. The water quality supplied into the network, per se, is not changing, its just how long it has sat in the network / pipework or if it has reacted with parts of the network infrastructure. Would I use a water filter? I dont think so. Unless you are scrupulous with the hygiene on these things and you are dumping the water at the end of every day, you are basically risking creating pond water as you are removing the disinfectant that stops bacteria etc growing in it. One of my jobs, early on in my career was testing public and private water supplies and bottled water plants. Samples taken from filter jugs (left out in sunlight for a few hours) - always failed the coliform test). You keep Britta filter jugs etc in the fridge for a reason - not to give you nice cold water to drink, but to slow down the bacterial growth in the water, that you just removed your protection from.
I presume that you are talking about using an in-line softener, either on the incoming supply or on a single drinking tap. A softener is basically a means of removing minerals from your water, that calcify when the water is heated or boiled. From a health perspective a bit of extra calcium in your drinking water will certainly do you no harm. From an aesthetic and engineering perspective it is a nuisance.we steam >95% of veg , so it wouldn't be immersed in questionable water.
