It’s the fastest available but turn on those features and well...FPS tank....and DLSS is a blurry mess.
And only doable on 2 games...
By the time the feature set is there if it ever gets developed more...then 2080 series will dead tech....so yeah it’s a crap gpu.
It would be a good gpu , if you could use the features have a solid FPS boost and not have a downgrade in image quality while using DLSS without paying nearly double for the privilege coming from the previous gen.
But sadly that’s not the case...factor in failure rates, and the 2080 series is a damp squib
The Radeon 7 is pants aswell...Two years on from a 1080ti and AMD release basically release a 1080ti with huge power draw, heat and noise...
