- 31 Jan 2012
- Droitwich, UK
A 3GB 1660? Ridiculous in 2019. 6GB on the 2060 is questionable enough for resolutions beyond 1080p moving forward.
3GB wouldn't power my dishwasher!
They're just setting up the pricing ladder & going to have GPU variants at each pricing interval, so there's no big jumps in-between. E.g. if you look at AMD you had very big jumps between 570/580 & Vegas (before all the recent deals) in terms of pricing (still do, >£50; used to be ~£100ish), but Nvidia had something within ~£50 of each card.
Don't forget the 1660 comes with 3GB VRAM.
No, the 1660ti had 6GB Cram.
There is some kind of 1650 modem with 3GB
If you have observed the nature of how graphic cards are over the years, then you'd most probably recall that cards with new architecture generally are more efficient and deliver better results for published benchmarks due to specific optimisations. In real-world gaming though, I would bet 95% times the 1660Ti would most likely be slower than the 1070, though for new games I would guess it would be the other way round moving forward due to the continual support that the 1660Ti would get that the 1070 would not. So I guess it's down to individuals to decide what's 1660Ti's performance meant for them, depending on if they are going to be playing new and future releases, or backlog of games which they have not got round to play.GIGABYTE GeForce GTX 1660 Ti OC pictured, benchmark leak, price confirmed
https://videocardz.com/newz/gigabyte-geforce-gtx-1660-ti-oc-pictured-benchmark-leak-price-confirmed
Yes it is GTX 1070 peformance accorded to Final Fantasy XV benchmark.
That HS is naff for $280.
Fake
Not fake.
It could easily be fake, have you not seen fake cards, usually crappy heatsinks, and the information that gets reported is all manipulated.
https://www.kitguru.net/components/...lson/nvidia-admits-dlss-needs-to-be-improved/
Wow now nVidia are admitting that the DLSS part of the new RTX cards isn't working properly and needs to be improved! What is the point of buying one of these cards when the hype turns out to be just - well hype?
