Currently running:
i5-3570k @ 4.8ghz (no idea whats cooling it, but its crap.. 65deg idle)
16GB DDR3 RAM
Asus GTX 780
Z77-D3H Mobo
So I think its time to upgrade..
On a budget
Been looking around at whats new, a bit out of the loop if i'm honest, but i've come up with the following :
i5-9600k
16GB Corsair Vengeance 3000Mhz
Asus Z390 TUF Gaming Plus
Gigabyte Windforce Edition RTX 2060
I currently have a Zalman Z11 Plus case with an EVGA 700w PSU which im hoping to repurpose, case probably needs some better fans. Failing that the Corsair Carbide 275r looks ok.
Hoping to OC the CPU to 4.8Ghz and have been eyeing up the be quiet Dark Rock 4 cooler.
Now, questions.
Asus boards, I hear a lot of horror stories about RMA and other issues, should I go for the equivalent Gigabyte board (Gaming X) always had Gigabyte boards and never had any issues.
I've also been told the Asus board isn't really capable of an overclock that's worth while, anyone got any experience with this?
Also that I''ll definitely need at least an All-In-One cooler for overclocking, seems a little crazy that a TDP200 cooler isn't sufficient?
I've no use for any of the fancy RGB nor SLI, I just want a basic board that will let me OC and that will last a good few years. Do i even just go for the Gigabyte UD
Thoughts on the 9600k? Worth the extra £20 over the 8600k?
Thoughts on the 2060? Worth paying extra for a 1070? cant quite stretch to a 2070..
Might be worth adding im looking to buy the cpu+mobo+ram+cooler as a prebuilt bundle pre clocked so i dont blow it up
My head is spinning!!
Help!
16GB DDR3 RAM
Asus GTX 780
Z77-D3H Mobo
On a budget
i5-9600k
Now, questions.
Help!
