GTX 1660TI
21 Mar 2012
Unless you locked into gsync, though why you would have spent money on a gsync montor and be buying this level card is a mystery, but why wouldnt you just get a sapphire 56 and 3 free games, crazy lol
27 Jan 2009
What a waste of time at launch...
Ignoring the RTX features you can get a 2060 for just over £300 that's faster and comes with a game from a choice of two titles.
Caporegime
18 Oct 2002
Looking at the TPU review the TU116 is around 284MM2,which is around 40% larger than a GP106. So for 20% more shaders the die size has increased by 40% and the transistor count has increased from 4.4 billion to 6.6 billion!! So its not only the RT and Tensor cores which add to the die size,but the basic shaders have grown in size too.
Because Turing is a whole new architecture with a lot of big changes under the hood. this was Somewhat glossed over because nvidia focused on RTX and DLSS giving people the false impression that Turing is pascal with RTX+Tensor cores bolted on. The reality is Turing is a big step up in IPC, efficiency, load balancing, and normalized performance with new features such as mixed-precision OPS, unified memory, concurrent FP and INT ops, variable rate shading, along with twice the cache size.
https://www.anandtech.com/show/13973/nvidia-gtx-1660-ti-review-feat-evga-xc-gaming/2
https://www.anandtech.com/show/13282/nvidia-turing-architecture-deep-dive/4
20 Apr 2004
Oxford
I think it kinda makes the 590 looks a little silly, not much cheaper (£20) but chunk slower, and twice the power of a 1660ti. Vega 56 is great value but AMD will be taking a hit/making a loss. The Free games you get the 590/V56 is a boon on the value front (if you want them) but they won't be there forever.
Navi really needs to come soon and have at least twice the performance per watt.
8 Jan 2019
MSI HQ
Under 300 Actually :p
Palit GeForce RTX 2060 StormX 6144MB GDDR6 PCI-Express Graphics Card @ £299.99 inc VAT
NE62060018J9-161F, Boost Clock: 1680MHz, Memory: 6144MB 14000MHz GDDR6, Cuda Cores: 1920, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, Real-Time Ray Tracing, 2 Years Warranty
Only £299.99 inc VAT.
ORDER NOW
28 Sep 2014
Scotland
Very impressed with reviews BUT not £259+ with no game bundle which made GTX 1660 Ti very poor value.
You would much better off buy Palit RTX 2060 for just £299 with 1 free game worth £54.95 of your choice either Battlefield V or Anthem plus it has RT and Tensor cores enabled.
Guess GTX 1660 Ti has hidden or disabled 192 Tensor cores.
bru
bru
21 Oct 2002
kent
10 Dec 2004
Oxfordshire
doesn't look to be a terrible set of results coming out for it, but then again it is nothing special at the price point I guess,
Shame, was interested to see if it was a mid-range beasty
The love for the 980ti continues in my household then
23 Aug 2005
It's not terrible then, good at overclocking. However I'd still recommend a second hand 1070 8GB for £230ish over this (that's what I did), because its faster/cheaper.
Man of Honour
26 May 2012
not so sure, depends on where you bought it from, of course. if the 1070 was sub-£200 yes, definitely the 1070 is the better deal.
but for 30 notes more, at £260, the 1660ti has 5 years warranty with zotac (and a free game fwiw) [error]
23 Aug 2005
True. I like MSI though :)
I've not had any bad experience with second hand stuff (don't buy it that often). I assume thats what seller feedback scores are for. I'd even have no problem buying from a cyptominer - surely that proves the card stands up to being tortured 24/7/365? If that ain't a solid card I don't know what is! :)
Also I wanted a card with that zero fan tech on it which you have to be careful you get, the lower cost cards don't always have that.
21 May 2018
South Wales
but for 30 notes more, at £260, the 1660ti has 5 years warranty with zotac (and a free game fwiw).
I don't see a free game? What is it?
Man of Honour
26 May 2012
@keyser thing is, hard to predict when the GPU will fail...may be 10 years, may be 10 minutes.
if bought preowned, unless the original buyer agrees to help with the RMA (if still within warranty period), will be SOL.
ah. my bad. mistaken. it's for 2060/2070 only :( post edited above
23 Aug 2005
I've never known a GPU or CPU to fail tbh. Motherboards yes (at work) and power supplies (2 at home under warranty, loads at work). I guess its anything with capacitors that can go. It's a risk/reward ratio, I'm fine with it. It's a stop gap upgrade before a big one next generation (maybe, depends if that gen doesn't suck).
My Z77 motherboard is out of warranty!! maybe I shouldn't overclock it.. nah :)
