- 22 Mar 2017
- UK
Holy crap! Hard to believe but it's been about six years since my last PC build. The good thing is my budget is slightly higher now. The bad thing is my current PC is dying very rapidly so I'm on a bit of a schedule.
Key requirements:
Other relevant info:
Few ideas:
Overclockers UK:
Key requirements:
- Fast at running multiple Windows VMs with multiple high-RAM Chrome tabs in each
- Many high CPU Flash instances in each VM (probably need an i7/i9 or is Ryzen my best bet?)
- Must be able to run 4+ monitors with ease
- Quiet is preferable - my current system is mostly fanless (maybe a 9700 will be quieter and colder?)
- 32 GB RAM minimum, probably 64GB (more RAM is more important than super fast RAM)
- Ballpark budget £2k?! Actually might need to revise that down a lot as want to get new monitors. I really don't know, let's say closer to £1.5k.
- Don't need keyboard, monitors, mouse, etc.
- No gaming so only graphics performance required is for running the screens. Graphics cards is where the biggest gap in my knowledge is (although also have zero clue about cases). Especially considering I'd prefer quiet and low power.
- Will sort my own storage too. Have a 2TB SSD for system partition, everything else will be from the NAS
- Easy upgrade to 10 GbE if required later preferable
- AMD/Intel agnostic
- Agnostic about form factor - anything from ITX to ATX is good
- Ability to upgrade in the future not vital
Few ideas:
- 1 x OcUK Tech Labs AMD Ryzen Pro Gaming PC Configurator = £1,750.84
- Case
hanteks Enthoo Pro M Midi Tower Case with Window - Black - Build Time:Standard Build Systems - Dispatched in approx 7 working days
- Motherboard:Asus ROG Strix X370-F Gaming AMD X370 (Socket AM4) DDR4 ATX Motherboard
- Memory:Kingston Fury Black 64GB (4x16GB) DDR4 PC4-19200C15 2400MHz Dual/Quad Channel Kit (HX424C15FBK4/64)
- Power Supply:Super Flower Leadex II 1200W 80 Plus Gold Modular Power Supply - Black
- CPU Cooler:be quiet! Silent Loop Superior Liquid CPU Cooler - 280mm
- Processor:AMD Ryzen 7 2700X Eight Core/Sixteen Thread 4.35GHz Processor (MPK)
- Graphics
alit GeForce GTX 1050 StormX 2048MB PCI-Express GDDR5 Graphics Card
- Case
Overclockers UK:
- 1 x **B Grade** Asus TUF X299 Mark2 (Socket 2066) Intel X299 ATX Motherboard= £150.00
- 1 x Intel Core i9-9900X (Skylake X / Basin Falls) Socket LGA2066 Processor - Retail= £929.99
- 1 x Corsair Hydro Series H150i PRO RGB Performance Liquid Cooler - 360mm (CW-9060031-WW)= £142.99
- 1 x CorsairVengeance SODIMM 64GB (4x16GB) DDR4 PC4-21300C18 2666MHz SODIMM Kit (CMSX64GX4M4A2666C18)= £455.99
Total: £1,690.07 (includes shipping: £11.10)
- 1 x OcUK Tech Labs Intel X-Series Workstation PC Configurator = £2,936.90
- Case:Corsair Obsidian 500D Midi Tower Gaming Case - Black Tempered Glass (CC-9011116-WW)
- Graphics
NY Nvidia Quadro P400 DVI Low Profile Graphics Card - 2GB GDDR5 - 256 CUDA Core - Primary Solid State Drive:WD Blue 3D NAND 250GB M.2 2280 6Gbps Solid State Drive (WDS250G2B0B)
- Power Supply:Kolink Continuum 1050W 80 Plus Platinum Modular Power Supply
- Cooling:be quiet! Silent Loop Superior Liquid CPU Cooler - 360mm
- Motherboard:Asus Prime X299-A (Socket 2066) Intel X299 ATX Motherboard
- Memory:G.Skill Trident Z RGB 64GB (4x16GB) DDR4 PC4-25600C14 3200MHz Quad Channel Kit (F4-3200C14Q-64GTZR)
- Processor:Intel Core i9-7920X 2.9GHz (Skylake X / Basin Falls) Socket LGA2066 Processor - Retail
