What Macbook to get for University/Work?
24 Feb 2019
Hi,
basically I'm going to, as soon as I narrow down my choices & options, going to buy a Macbook. However, I'm not particularly sure where is the best place to buy one (other than I know Apple has a Student discount), or which model is going to fit what I need. I have a budget of around £1,300 & I would use the laptop for general university work but also for using Creative Suite, more specifically things like Illustrator, Photoshop, InDesign & Premiere, which I use for my job.
Any advice on what to get & the best place to get it is appreciated.
Cheers! :)
Kol
Kol
Man of Honour
8 Jan 2003
Ashby-de-la-Zouch
£1300 (well, £1330 something) will get you the 13" touch bar MBP. rather than the entry level. The pitiful discount is now 10%, the good ol' days are gone but better than nowt i guess :|
14 Apr 2014
Sunny Sussex
If you're getting a Mac, you want to be getting at least the 13 inch with Touchbar, and the 2018 model. Anything else will be underpowered for the stuff you're working on.
Really, I would be getting a Dell XPS 15 in your position.
