Caporegime
- 18 Sep 2009
- Dormanstown.
Gibbo has mentioned it.
More likely July earliest, September most likely and worse case November as there has been delays pushing it back further.
Plus its doubtful it will be able to offer Vega 56 performance for less than £200.
The main advantage is smaller die, cheaper memory and most importantly much larger profits for AMD which they desperately need to do in order to survive in VGA game, otherwise just be better to pull out and make CPU's where you make plenty of money, using the CPU business to keep VGA business afloat is very bad practice for long term.
I feel Navi will be good, great value and most importantly AMD's profits will further improve.![]()
If that card is still in production, now, if they are not just selling off surplus stock they are in trouble...
Don't care at the moment, Vega 56 for £200 after selling the free games is insane value that I'll be very surprised if Navi even comes close to the performance per £
Didn't Adored hint that AMD had to respin them causing the delay we are seeing?
I don't think so. RX Vega 56 is superior than 1660 Ti in all characteristics. They must keep it alive.
I reckon Navi is nearer than we might expect and that's why this generations prices are dropping so much
I think it'll be close. Last time AMD haved it's NM process we had the 480 outperforming the 380 by 40%. So if top level Navi does the same with the 580 replacement it'll be on par with Vega 56 and the 2060 performance wise. But the move to GDDR6 should see a bigger gain in theory, so maybe the rumours of 1080 or 2070 performance out the box are true. Plus you get a quieter card. But then again the better it performs the more it's probably going to cost.
I generally won't pay £300+ for a GPU, not these days. However, below £300 you have got my attention, and at £250... that's hard to pass up!
GPU prices really do need a massive shake up though, because frankly some of them are daylight robbery! Mining is done, so supply isn't an issue any more, it's greed.
Raw performance, just, a little bit more ram sure, but all characteristics erm no
How is it greed when AMD are selling you a card below what is cost them?
Vega 56 is a $399, yet were selling them at $279 which is pretty much a loss to AMD, as a manufacturer to be truly healthy they should make 50% on the product, to cover R&D, wages, logistics, so how anyone can even remotely utter the word greed towards AMD is nothing but appalling.
They give the gamer so much, during the mining craze, AMD never changed prices, it was board partners and resellers. In fact as the mining hype was kicking off AMD was smashing out HD 7990 cards at massive losses.
But we're in a place now where Vega is more than enough to run any game pretty well. Why spend more? Nothing is really progressing.
Yeah, its a great card for little money, but i can't see AMD making any money on those now, i suspect they are losing money on everyone they sell and as you yourself said its really not good having the profitable part of the business prop up the failing part.
I would rather AMD stopped making retail cards than run their business like that, we can't have the retail GPU part of the business draining resources away from everything else.
Reviewers disagree on the " another league". When 6gb becomes issue the performance wont be there like with vega56."Little bit" more memory is 2 GB more, which is 33.33% more and it's the state-of-the-art HBM2 memory. Raw performance is in another league
A pointless metric, AMD gpu's have always quoted higher theoretical figures. Ask your self if V56 has almost double the "Gflops" why is the 1660ti performance.10,566 GFLOPS for the RX Vega 56 vs only 5,437 GFLOPS for a 1660 Ti, which is 100% more.
See above eps in gamingFP64 performance is 660.4 GFLOPS for the RX Vega 56 vs only 169.9 GFLOPS, which is 288% more.
Texture rate is 330.2 GTexel/s for the RX Vega 56 vs only 169.9 GTexel/s.
Memory bandwidth is 409.6 GB/s for the RX Vega 56 vs only 288.0 GB/s.
This old chestnut. Its been donkey's years since there was a differenceImage quality, the geforce can not match, so think once again
Vega 56 is the quicker card of the 2 though so the numbers do mean something though it definitely isn't as cut and dry as "Vega 56 has 288% more FP64 so is 288% quicker".
- Jim, changing topics, are you planning on making any update on the info about Navi? Any info, rumors, that we don't know about, yet?
- I might talk a bit about it in a near-future video but the news is pretty thin on the ground and most of it has been bad.
- Define "bad".
- Well two phrases I've heard in the last week from two different sources were "Navi horror stories" and " Navi has been a nightmare".
Grain of salt, as usual.
