Need a 24" 4K monitor
21 Apr 2016
Oh Canada!
Need advice on a 24" 4K monitor. No need for anything above 60Hz. Want IPS and extremely accurate colour. This will be my secondary monitor and will be used exclusively for video playback and similar use so the tiny text size @ 4K/24" is a non-issue.
Suggestions plz!
Permabanned
2 Sep 2017
Suggestions plz!
Hi there,
All available options are as follows:
LG 24UD58
AOC U2477PWQ
Dell P2415Q
Viewsonic VX2475SMHL-4K
Asus MG24UQ
Philips 241P6VPJKEB
Hewlett-Packard HP Z24s
NEC Display Solutions EA244UHD
Samsung U24E850R
Samsung U24E590D
Choose one of the above.
OP
21 Apr 2016
Oh Canada!
Hi there,
LG 24UD58
AOC U2477PWQ
Dell P2415Q
Asus MG24UQ
Philips 241P6VPJKEB
Samsung U24E850R
Samsung U24E590D
Which of these has the widest color gamut and is pre calibrated the best, colour wise?
Permabanned
2 Sep 2017
Personally, I lean towards the Japanese quality. The NEC MultiSync® EA244UHD LCD 24".
https://www.nec-display-solutions.com/p/eeme/en/products/details/rp/EA244UHD.xhtml
Panel Technology IPS TFT with W-LED backlight
Screen Size [inch/cm] 24 / 61
Screen Aspect Ratio 16:9
Pixel Pitch [mm] 0.14
Brightness (typ.) [cd/m²] 350
Contrast Ratio (typ.) 1000:1
Viewing Angle [°] 178 horizontal / 178 vertical (typ. at contrast ratio 10:1)
Response Time (typ.) [ms] 5
Colours [Billion] 1.073 (10-bit per colour)
Colour Gamut Size / Coverage 107% / 99% Adobe RGB
OP
21 Apr 2016
Oh Canada!
22 Mar 2017
UK
Hi there,
LG 24UD58
AOC U2477PWQ
Dell P2415Q
Asus MG24UQ
Philips 241P6VPJKEB
Samsung U24E850R
Samsung U24E590D
So it's about 18 months later and there don't seem to be any new 4K 24" monitor at all. Most of these are end of life and the only ones that seem to be in good supply are:
Dell P2415Q - https://www.overclockers.co.uk/dell...reen-led-monitor-midnight-grey-mo-079-de.html
LG 24UD58 - https://www.overclockers.co.uk/lg-2...creen-led-gaming-monitor-black-mo-14b-lg.html
Like the OP, I have no need for anything above 60Hz. However, I do want to run these in a quad-monitor setup so two important facts are bezel size and price.
Unfortuantely it seems you only get small bezels when you go up to 27" but I think a 27" quad set-up would be too wide for both my eyes and my desk.
Why are there so few 24" 4K monitors available? And can I do any better than the LG 24UD58 in 2019?
22 Mar 2017
UK
What do you use quad 4k monitors for?
Work. Spreadsheets, dashboards and billions of Chrome tabs. Often a different VM in each monitor. It's not a huge amount of space and I can't see it being that uncommon a request?! I'm currently struggling really hard with two 22" 1080p displays.
Will my Radeon RX 570 Pulse 8GB have any issue just running Windows apps at this resolution?
