If I get an M.2 Sata hard drive, can I make it any drive letter?
15 Nov 2003
Marlow
ie: I already have a regular SSD Sata, so can I plug in a new M.2 Sata hard drive into my motherboard, and treat that as say my X drive, and continue to boot of my old regular SSD Sata?
ie: Assume there's nothing super magical about the M.2 port and it forcing itself as the primary drive?
Yeah, they're nasty if you have large CPU coolers.
Having just read they're baically the same speed as a regula sata, unless you get the "full spec" versions, I might just go regular sata because of just that!
ps: Looking at Crucial MX500 or Samsung 860.
What did you look at? NVMEs are considerably quicker than regular sata. Look at the Intel 660p mate, I have one and it superb!! They're 3 times quicker, if not 4 in some instances.
You want an NVME for speed
I have one of these and the speeds are amazing
https://www.overclockers.co.uk/sams...-3.0-x4-nvme-solid-state-drive-hd-23n-sa.html
Yes, given I want a 2TB drive that could prove pricey compared to a regular 2TB Samsung/Crucial SSD?
My only comment on this would be check out the Intel 660p, that 970 is overpriced in comparison to the 660p. You get more from the Intel and its a shame OcUK do not stock it.
Why not get the 1tb NVME and then a regular 1tb ssd?
The goal is to put my D drive - a standard 1TB - which has all my games on, and which is full, onto a new 2TB SSD.
ie: Speed and loads of room for the future.
I tried Sandstorm on my regular hard drive and then on my C drive SSD, and the loading difference is astounding! And that's with a very old SSD too!
So the 2TB is more important than the speed of the SSD! But having looked that 660p is seemingly available in 2TB size for a similar price as the Samsung 860. And it has a 5yr warranty like the Samsung!
I wouldn't pay that much for it so would wait for a reduction/deal.
I've got the 660P 1TB coming got it for a hundred quid. A bit worried about endurance and for large file transfers apparently goes below HDD speeds which is a bit cack but for most transfers and installs should be ok. For game loading it seems to be as fast as most NVMe's.
Well at least the 2TB one I'd be looking at is rated as twice the endurance as the 1TB. But as I'd only be using it as a games drive, and given many games are tens of GB big, is that an issue or not? ie: Loading up Rainbow Six Seige over and over which is around 65GB in total in disk install?
That's surprising as I though it was suppose to be significantly faster than even SSDs?
This video review raises a few question marks about the 660p, indeed even questioning at times if its faster than the Samsung 850/860 SSD?
https://www.youtube.com/watch?v=OffzVc7ZB-o
Some other reviews have shown as the drive gets full its speed even halves, to say even slower than a regular Crucial MX500...
It risks feeling a touch spit and gum?
