Is that upload speed correct? I know that their upload speeds have always been a bit underwhelming, but that's pathetic.
The advertised upload speed for the Vivid 350 is 21Mbps.
https://www.virginmedia.com/shop/broadband/speeds.html
Ah, ok. It's odd that isn't available where we are. Does it utilise different hardware?
Anyone else found an option which would work? Not sure if I understand why screw on is no good...No good, screw on connectors or just cheap looking cable.
You did notice it’s a *Business* plan and not residential right?
I posted a link in response to youAnyone else found an option which would work? Not sure if I understand why screw on is no good...
Yes, I did. It says the local infrastructure will only support 38Mbps, but the residential will do 350+. Hence why I asked if it uses different hardware.
People. Is the Linksys WRT3200ACM-UK MU-MIMO still a good router so I can put the SH3 in modem mode?
I need to block websites and the SH3 can't do it.
Thats what I use with Sh3 in modem mode, its decent enough on the whole. Though could be better in some areas, interface and some options lacking.
If your only wanting to block sites try pi-hole? Raspberry Pi will set you back around £40 or setup a VM.
https://forums.overclockers.co.uk/threads/setting-up-pi-hole.18756115/
Thank you
Have you tried OpenWRT on it?
That looks great.
But I should have said that my carer has to be able to deal with it![]()
No as from what I can gather, despite its name, WRT has issue on it so never bothered.
People with more knowledge may correct me on that and I have not looked into it for months so may have changed.
Does say its supported on dd-wrt website but cant get onto forum thread at the moment to check its current status. Might have a look later.
