- 7 Mar 2019
I currently have 4x8 sticks. Is this better or worse than 2x16?
makes no real difference
what motherboard and CPU do you have?
4 sticks can lower you overclock potential as it put extra load on the memory controller. but that said unless your pushing for world records it makes no difference
Interesting. Do you mean the overclock of the ram or the cpu? I have the i9 9900k and rog maximus XI formula z390 board
coolboth really, but the main one been the CPU.... BUT that said we are talking 100/200mhz
like i said unless you pushing for world records no real difference. you CPU @5ghz V's 4.85Ghz is nothing
Edit: you could even have a strong memory controller and the clocks be the same,
cool
my ram is the g skill trident z @ 3200mhzthe question would be what ram, speed and timing do you have
trident z is by no means high end, but is good solid ram stick with the 4x8 set up until 32GB is no longer of use and you forced to upgrade.
Nothing wrong with Trident Z, mine is even Samsung B die and didn't cost a fortune either.
