be quiet! Silent Loop AIO is made by Alphacool to be quiet! specs. Only complaints I've heard is sometimes coolant level needs to be topped up after 6 months or so to stop pump noise from air moving through system. Easy to do with an eye dropper.Nice info here - I'm also the look out for an AIO (although for a much older CPU). I'm already looking at fans and was heading towards Be Quiet Silent Wings, so interested to hear they have their own line of AIOs as well. Will check them out, as I was leaning towards a Kraken X72.
Silver Arrow SB-E, Silver Arrow SB-E Extreme vs H100
I7 [email protected] Temperature in Delta
Cooler . . . . . . . . . Delta . RPM . . . . . . dB(A) . . Fans
H100 . . . . . . . . . . 41c . . 2500. . . . . . 55 . . . . 2x
SA SB-E. . . . . . . . 42c . . 1000 & 1300. 38 . . . . TY-150 & TY-141
SA SB-E Extreme . 34c . . 2500 . . . . . . 56 . . . . 2x TY-143
H100 is 1c cooler than Silver Arrow SB-e but makes more than 3 times the noise doing it
Silver Arrow SB-E Extreme is 7c cooler with fans making similar amount of noise as H100 does.
PC-Cooling video review above data came from:
I didn't want to go cheap custom loop for a while but at £180 I'm sure I could get enough for a CPU loop. So many choices right now
could do a GPU and CPU block depending on the graphics card.
Running a radiator as intake means it's pre-heated the air that is used to cool everything but what CLC is cooling .. hardly a good idea considering that air cooling has basically a 1:1 ratio of air temp into cooler vs them of component .. as in raise air temp 5c to a hot component and it's temps also goes up 5c.
Water cooling isn't that 1:1 ratio, so air temp into radiator is not as critical
air that goes through an AIO radiator cooling a CPU isn't heated up that much and is better than trying to use the much hotter air from inside a case to cool the rad.
Running an AIO rad as an intake is better than an exhaust. The only rad I run as an exhaust in my systems is the one attached to the kraken G12 cooling my RX480 because I don't want that hot air coming into the case.
Better explanation than mine.An individual millilitre of air will be cooler coming through a large radiator, than a small one. But the overall amount of warming has to be the same, it's just spread over a large volume of air. But then if it's all inside your case, it's still going to warm it up by the same amount overall.
Your CPU will be cooler, because you're effectively using room temp to cool it, which is great. But then, you'll be helping to cook your GPU, and perhaps worse, your VRMs, which will potentially throttle/burnout your CPU anyway.
If you setup decent airflow into the case in the first place, then exhausting through the rad may add a small amount to your CPU temps (which would be well within safe levels anyway), whilst also allowing the rest of the vital components to stay cooler too.
So you have top and front intakes .. say 2x 140mm top an 2x 140mm front intakes means you need 4x 140mm exhaust vents ideally with fans like your intakes to be moving air out of case at same rate as intake fans push it in. If you don't have at lest as much exhaust flow as intakes are capable of your case's maximum flow will be limited by the smaller exaust airflow rate.only heat up the GPU if you don't have any other intake. current ryzen 2600 is cooled by top mounted intake rad and the GPU cooled by front inlet. No difference in gpu temp if it is run as in take or exhaust.
