a burlap sack and suitably heavy weight should sort out the cat allergy......well, technically the allergy still exists, it's just the cause will have been removedWhat do you guys recommend or use to control pet allergies?
a burlap sack and suitably heavy weight should sort out the cat allergy......well, technically the allergy still exists, it's just the cause will have been removed![]()
Much as Vidar's ex is a complete mentalist, this is a bit extreme.
My lad may have an allergy to cats... What do you guys recommend or use to control pet allergies?
Get your lad properly tested. As for control, it's the cat's dander that is the issue. As long as I don't pick the cat up and wash my hands afterwards I'm fine. Having a cat in the house is a no-no, though.
