- 28 Jun 2005
Very neat and tidy. Lovely! I wish I could tidy mine up but don't know best to neaten 4 workstations with a switch currently laying on top of them.
nfortunately the official shelves for the servers are about £100 each, but I wanted it all neat so bit the bullet anyway.
I'm not sure if you can tell, but the QNAP NAS sits on a tray next to the little 8 port switch. The two trays will go into the two spare U slots however the top of the QNAP protrudes a few mm over the bottom most U. I'm sure I can make it work, just have to look into it when they arrive which may be some time as I suspect they're coming from the US via the UK distributor I use for SuperMicro kit.
https://www.uk.insight.com/en-gb/productinfo/network-racking-and-cabinets/0005002165-00000001Do you have a link for the Startech cabinet you purchased?
)@ChrisD.
Just bumping this as I am investigating setting up a home lab again so interested on how you are getting on with it all. Back in the day (when I used to do VMware architecture & consultancy) I had a full blown lab with more enterprise type kit, a HP C3000, an F5 LoadBalancer and a NetApp 3140 with a couple of trays, etc. My requirements have now changed as I've moved away from VMware across to more cloud orientated stuff (AWS, GCP, Containerisation, etc).
I'm trying to weigh up whether its worth separating out the storage and compute (so something lightweight like a NUC and then a QNAP presented over NFS) or an all in one (so ESXi and then present local storage with something like FreeNAS or equivalent). I will still run ESXi as the core either way. One of my current projects at work is OpenStack so I'd layer this over the top of CentOS VM's for example.
Loving your setup by the way, I don't think I need 10GB on the backend however (yes I am jealous)
It all boils down to your budget.
I was solely running off a whitebox build with i7-3820 & 64GB with a P410 raid controller and everything nested up until very recently.
I now have added a SuperServer 5028D-TN4T with 128GB plus a 4 bay NAS as my main work testing area (still nesting), with the old box still running my media servers & home infrastructure.
The NUC will be limited to 32GB, but I have seen over at virtually ghetto that people are reporting running 64GB in them.
the world of homelab has certainly changed from back when I was doing it!
I don't have a budget so to speak, I'm quite open in that respect (obviously I don't want to spend a ridiculous amount). I'm leaning towards a 'big box' approach as opposed to separation as on the backend my bandwidth will be limited if I go for external storage. I luckily have a spare bedroom so not too fussed about keeping it micro or keeping the noise down, it can hum away in a corner. That 5028D looks very sweet I must say, I'm a huge fan of SuperMicro (I used to spec up some custom supermicro NVMe servers via a reseller over here called Broadberry).
The debate now is whether I pick up something like a PowerEdge (or equivalent so it can run esxi 6.7, doesn't necessarily have to be on the HCL) although I am now seeing a lot of builds based on Ryzen, etc. A must for me is to have local storage, so a couple of SSD's for 'speedy' VM's, and large SATA's on a decent RAID controller. I still would like to use VMFS. Ideally I don't want to rely on a separate VM for presenting out the storage (so having FreeNAS running in a VM for example). I'm worried about raw throughput and having a dependancy on a VM to present the main storage for other VM's is a concern. Like you I'd want 128GB in the server.
I think I may have answered my own questionthe world of homelab has certainly changed from back when I was doing it!
*edit
I am now looking at a ThreadRipper setup!![]()
However I've upgraded my gaming PC to a 3960X along with 256GB of RAM (still waiting on the RAM).
The 12 generation Dell servers are now hitting EOS/EOL, so you should start seeing a lot of those hitting the usual places.
Try https://uk.labgopher.com/ if your heading down that route.
Cheers, I started late August. It's a great company to work for.Work for VMware, nice![]()
