- 27 Mar 2013
It was to the guy that suggested it was feedback from solar panels, surely if it sounds the same day or night, it can't be related to panels.
The issue with solar panels is actually an issue 24/7 because regardless of day or night, the inverter that solar panels feed is on 24/7. The inverter itself is the biggest polluter of mains electricity.
I don't know the correct term to use, but has anyone considered it's low power in your area at peak times. For example I use to live in a house that around 8am the kettle took longer to boil due to other households I presume also boiling tea at that time. Is there any device that could measure this?
You might be on to something here. The more I think about it, I'm convinced it's a mains issue and as I've previously mentioned, I mostly listen to music late Saturday afternoon, early evening, which could well be a peak time on the national grid round here. I've noticed many a time that my hifi does sound better after around 6.00pm and over the years there have been a few power cuts around this time as well.
I want to get to the bottom of this and get it resolved as when everything is working to its full potential, its quite magical, rather than the rest of the time when it sounds harsher and tiresome when it's only running at about 90% of full potential.
I will happily fork out for a 'something' that will improve my mains supply if someone can demonstrate to me that their solution will make the difference.
PS Audio Power Plants do apparently. From everything I can gather these units convert AC power into DC, then reconvert the DC into AC. The AC output to your hi fi gear is then 'perfect' or close as regardless of how poor the incoming mains AC is.
You can think of it like charging a battery from an AC mains adaptor. Then when you use the battery the output will be the same regardless of how dirty or poor the AC was to charge the battery.
https://www.youtube.comt/watch?v=XaRuFeEYTWQ
basically snake oil. they will help you if you have issue sbut if you don't they won't make any difference.
I also did a test where I ran a Powerline adapter from the mains conditioner, and the Powerline adapter reported significantly lower sync speed.
Isn't this thing a voltage regulator? I'm not surprised it would mess with powerline sync speeds. The regulated AC is probably out of the powerline adapter's spec.
Those mains conditioners apparently take any peaks or spikes out of the AC.
I work from home most days, and as it happens i'm sitting in my front room now and just tested my down stairs stereo with and without the mains conditioner. It's subtle however with the mains conditioner the sound has more body and less muddy, more important sound is more relaxing with the mains conditioner, as said it's subtle however the difference is there.
Hmmm. Depends about the peaks and spikes, but really, it shouldn't make any difference. It's AC. it's going through a transformer well before it gets near the signal path. SMPS will take pretty much any old dirty AC and turn it into clean power.
As said I don't really understand how they work, however I can hear an improvement in the audio so I keep using them.
so you only need a conditioner if you have crappy electrics and a crappy amp/dac which can't deal with the RFI (possibly due to it being defective or on it's way out or cheap)?
