They sneak them back on. If you use something like ShutUp10 after an update sometimes things have re-enabled themselves.
I did not know about this, thanks
8.1 is crap compared to both 10 and 7 tbh.
As for those saying w10 is spyware fester, there are tools to turn everything off with one click.
And to those of us who remember, Windows 7 was blamed for been spyware fested crap OS compared to XP.....
But many have the memory span of a goldfish.
I dont ever remember windows 7 been labeled as spyware, the only windows OS with that rep is windows 10.
when windows 7 was launched vista was just as good as 7, but no one trusted it at that point, so microsoft released a vista SP4 as windows 7
Not really.
8.1 has half of the technical advancements of 10, but in terms of the control with the user is very similar to 7.
8.1 has suffered the same way vista did, it had a bad launch which meant its got a bad name, when windows 7 was launched vista was just as good as 7, but no one trusted it at that point, so microsoft released a vista SP4 as windows 7.
I mean you do need to use something like startisback with win 8.1, but once you do that its pretty much the same as windows 7 except its newer, and has some technical enhancements.
For me to make Windows 10 viable as an OS on a proper rig, the following is a minimal.
Disable feature updates or use LTS version.
Delay security updates by at least 15 days
In GP's set updates to check for updates only but not auto install.
Once you install updates, reboot right away, else you gonna get shafted by an auto reboot, the auto reboot setting in GP's seems to not get honoured.
Disable 80% of telemetry tasks in task scheduler, but not all of them, do not set telemetry to basic, as that prevents windows update defer settings from working.
Disable/remove cortana.
Install startisback or classicshell start menu.
At this point it becomes kind off viable for use.
Guys, if you complain so much about security, why you still stick to MS? Switch to Linux.
will my games run ok on linexGuys, if you complain so much about security, why you still stick to MS? Switch to Linux.
Because Microsoft have spent thirty years cornering the PC gaming market, buying devs out to use their APIs and generally being all around anti-competitive to anyone that tries to break their dominance?
pretty much this, if vulkan gets big or someone gets DX working properly on linux I would switch like today.
linux is also so much faster as well. Booting up a linux desktop on any of my rigs is night and day difference.
I gotta wonder if DX12 WoW in Win 7 works for those having GSync issues with borderless full screen in Win 10 (I understand WoW dropped its exclusive full screen option a while back).
It’s been a while and I prepared a lot of slides for DX12but generally the constraints imposed by WDDM 1.1 still apply to all low-level GPU hardware abstractions on Windows 7. In the end the Win7/WDDM 1.1 system design & policies around GPU memory management & scheduling constrain the type of application and user scenarios that low-level APIs can be successful driving on that platform. It works decent for 1-2 high resource consuming applications at a time, but the user experience does not degrade gracefully if a lot of apps running simultaneously start loading up the GPU with low-level API usage on Windows 7. That does mean there’s a number of AAA games & engines that benefit from it though. Workstation apps are another category where the user tends to run just 1 high resource consuming app at a time, but users in that category tend to go for more recent OSs as that’s where the official support channels are greatest.
Why D3D12 on Win7? We’re at the next stage for D3D12 and low-level APIs in the technology adoption curve by developers and publishers. The next order of magnitude in the title & engine population are now designing first, or *only* for low-level APIs. The devs & publishers are making a lot of tradeoffs as part of this process:
- How do they get the most fidelity, frame rate, and functionality out of the low-level API for each target platform?
- How do they reward gamers who bought high end hardware with commensurate high end experiences?
- How do they get the largest total addressable market?
- Widest variety of hardware
- On all the OS and device platforms where the gamers are
- While keeping the engineering cost within budget
There’s a measurable population of gamers in some markets that likely won’t get off of Windows 7 in time for this next wave of titles and engines on low-level APIs. D3D12 on Windows 7 is what my team did to assist developers & publishers with the engineering cost and addressable market tradeoffs they were making. Developers get to focus more time/spend less effort on making their engines & titles work better on D3D12, publishers have a reduced cost for reaching their market on Windows, gamers who are stuck on Windows 7 still get to play the games with the limits imposed by that OS, and Windows 10 gamers get a larger number of games that can more fully exploit their hardware. All together it was a solution my team was really happy to make possible.
The system constraints in Windows 7, as well as the well aged properties of the ecosystem (just think of all the random drivers & software hooking into bizarre internal methods that were never designed to be touched outside of OS code), are why we’re doing a title by title rollout at first. We need to make sure the experience is a quality one across users, developers, and publishers.
Max McMullen
Development Manager
Compute, Graphics, and AI (yes, we chose the group name in that order because the acronym was funny to us)
Microsoft
Probably because even to this day, Windows 7 has been the best OS they've done.I’m amazed anyone still uses Win 7, unless some legacy software dictates the need.
Some people just can’t let go.![]()
