Asrock B450m Pro4 MOBO X2 NvME SSD Slots?
1 Dec 2015
Hi Guys,
I'm looking at buying an Asrock B450m Pro4 motherboard https://www.asrock.com/MB/AMD/B450M Pro4/index.asp.
The specs indicate that it has x2 NvME SSD slots, does this mean I can have x2 of these installed and working at the same time, one for OS and one for Storage? SSD's https://www.adata.com/upload/downloadfile/Datasheet_XPG SX8200 Pro_EN_20181017.pdf
Thanks in advance!
- 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module
- 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Summit Ridge, Raven Ridge and Pinnacle Ridge)
one nvme and one sata 3 m.2 drives
MSI mATX is the same
itx board. dual m.2 nvme slots. one at x4 speed and other at x2
https://www.overclockers.co.uk/giga...ocket-am4-mini-itx-motherboard-mb-57h-gi.html
also has better VRM then the above boards and ram support being 2 dim only
OP
15 Mar 2019
Thanks Orbitalwalsh..
So I could then have these two m.2's running or am I still missing the plot?
x1 of ADATA 256GB XPG SX8200 PRO M.2 NVMe SSD, M.2 2280, PCIe, 3D NAND, R/W 3500/1200 MB/s for Operating System
x1 of ADATA 512GB Ultimate SU800 M.2 SSD, M.2 2280, SATA3, 3D NAND, R/W 560/520 MB/s for Storage
Thanks in advance!
1 Dec 2015
Thanks in advance!
you could. you wouldn;t notice much difference between nvme and sata3 just for an OS or gaming drive. Plays its hand in data handling for workload - like lightroom and mass image edits etc .
could just double your NVMe size for a single 512gb drive or larger 1tb Sata 3 m.2 drive
OP
15 Mar 2019
Ok cool. I've also just confirmed with Asrock themselves. I'm just going to go traditional and have one m.2 nvme as boot/os drive and a regular 2.5" ssd for storage.
Thanks again!
5 Dec 2010
Solihull
Hi Guys,
Thanks in advance!
You can run 2 x nvme drives on that board. One would need to be in a pcie adapter installed on the second x16 length slot on the board.
The MSI B450 mortar has a second m.2 slot for an nvme drive and wouldn't need an adapter.
In both cases, the second nvme drive will be limited by pcie gen 2 lanes from the chipset, so 20gbps vs 32gbps of the full speed slot. But still faster than sata (6gbps).
1 Dec 2015
check website and msi rep. one is nvme and second is sata 3 . unless they have got website wrong and EU rep with wrong info
5 Dec 2010
Solihull
I've looked up the board before, and I double checked before posting that info.
from the specs on the site:
AMD® B450 Chipset
  • 4 x SATA 6Gb/s ports1
  • 1 x M.2 slot (M2_2, Key M)1
    • Supports PCIe 2.0 x4 2242/ 2260 /2280 storage devices
AMD® CPU
  • 1 x M.2 slot (M2_1, Key M)*1
    • Supports PCIe 3.0 x4 (AMD® Ryzen 1st and 2nd Generation/ Ryzen™ with Radeon™ Vega Graphics) or PCIe 3.0 x2 (AMD® Athlon™ with Radeon™ Vega Graphics)and SATA 6Gb/s 2242/ 2260 /2280 storage devices
  1. PCI_E4 slot will be unavailable when an M.2 SSD is installed in the M2_2 slot.
From the images of the board you can also see that the second slot has the M key slot for an nvme drive.
5 Dec 2010
Solihull
@pandem0nium nice, didnt check full data sheet - saw raid 1/0 for NVMe :)
That's Cool, no worries. Nvme raid would be cool, I'd like to give that a go.
You can get full speed nvme raid in a SFF with the Asus X470 ITX. But would lose the nice space and extra expansion slots of mATX.
Hopefully with the next gen boards, we'll get gen 3 lanes on the chipset for better storage options.
1 Dec 2015
x570 has better storage :)
you'll also notice asus line up will look a lot like aorus, far cry from z390... pmsl
1 Dec 2015
Oh ok, great stuff. That's good to know. I'll look into replacing my B350 Mortar and 2700X when the new gen is out.
Do you have a connection to the industry to have that info?
I signed AMD NDA last to times around, to busy this time around with kids and 3rd one coming to do zen2/ryzen3*** :)
should also see prices some of the asus gear at distribution is ... some times can make a killing haha
intel too- 22 core should be coming to x299
29 May 2021
London (UK)
Hi all I just joined and this is my first post, sorry but.... I am a bit of a dimwit when it comes to stuff like this, and I may have made a rush purchase, I have the same motherboard, and I also have a SSD M2 NVMe (1tb- or 500 MB) in it now as well as an old hard drive 1tb, so I bought a new SSD to put in I read the comments, but I am still confused, do I need an adapter, or will it slot in some place? Thanks.
15 Oct 2019
Uk
A second nvme will work fine in the second m.2 slot but the speed will be limited to around 1500MB/s read and write even if you used a faster drive.
29 May 2021
London (UK)
It's OK I found it, it's right in the corner of the board, think I will do it tomorrow, when I bought this computer and put it together, I got 1tb of memory and thought that's enough for everything, and right now I have hardly any room left with games.... lol
15 Oct 2019
Uk
Ok looking at that board only the top slot supports m.2 nvme and the lower slot only supports a SATA M.2 so if both drives are nvme then you would need to use a PCIe nvme adapter in the lower pciex16 slot.
So you would fit this into the bottom PCIe x16 slot then mount the nvme on it.
My basket at Overclockers UK:
Total: £16.73 (includes shipping: £2.74)​
