The Division 2 - March 2019
Yah, as peeps said! I will add who I see invite but make sure you are in discord as well.
Wont accept people I don't see in discord unfort. (link in sig) not even for voice, but its good for sharing stuff
Brilliant fun this, thoroughly enjoyed my time on it today. The world feels fantastic, so much detail. Really like all the little world events as well and the missions seem really well done so far.
Performance is ace as well. Using DX12 here, not one crash today, romping along at 1440p high preset.
What can I drop to hit 60fps on a 2500k and 980ti - any easy wins to drop to get me them frames? :D
dont know about the cpu, but fog setting has a big impact on the gpu. Also the resolution % will obviously have a big impact also.
For cpu what I expect are most likely to help is things like the drawing distance.
so the game gives better gear out for clans? wtf?
He joined another agent,difficulty scales up a bit so are rewards,can join anyone on friend list if they ok,same thing,doesnt need to be clan member.
Tere should be no issues with drops as they are left and right anyway
None of you guys had this issue? I am pretty sure its a bug surely not deliberate.
Those guys who throw flame bombs and have suicide bombers.
On supply drops they get reinforced after 1 second if you kill the group. Basically an immediate "enemy forces incoming" when you take them out.
Given it takes about 5 seconds to open a crate and one suicide bomber wipes all armour plus 80% HP, clearly its whacked.
Also chromatic abboration cannot be turned off, it is on again when going back into settings (not an issue in beta).
Also the reasons some of you may be reporting better performance is object detail default setting is lower, I noticed in final game graphics quality went down, and after reading reddit realised the issue is object detail setting. I turned it back up to 100 now.
The damn drone and turrent bug is back, having to play crippled, might wait for them to fix it.
https://forums.ubi.com/showthread.php/2014430-Drone-and-Turret-skills-not-working-bugged
https://old.reddit.com/r/thedivisio...re_my_skills_turning_off_and_triggering_a_15/
I've just received the Div 2 from AMD rewards.
20min download, thank you Virgin :)
I've added the smg to my account and downloaded the game so I'm ready to play. All that is left is for my remaining PC parts to arrive so I can actually play :rolleyes:
You will need to be level three to use the msg as I did the same thing before playing lol
Finally got mine too! Took long enough.
I'll continue to play the game solo and not join the ocuk clan as I don't use discord or have a mic.
If anyone wants to add me my ID is EED209.
Quite enjoyed the first one and the beta. I find them mildly addictive
Think I may purchase from cdkeys and possibly join the clan but I don’t use a mic either unless I need to keep the noise down. In fact I must dig out my Astro’s I’ve not used in ages
