So I finally got around to pulling the trigger on my new build. Not all components but just the first few....which are:
My basket at Overclockers UK:
I think I've decided on the final PSU which will be the Seasonic 1000w Prime Platinum. Although I am debating whether to stick with the 1000w Dark Power Pro by Be Quiet but looking at cable management and advice from others on here...the former seems the better option for a few quid difference.
The CPU will be the Intel i9 9900K...so that's decided.
The other big component I am yet undecided on is the Graphics card. It will most certainly be an nVidia Geforce RTX 2080ti. I am looking for silence. As quiet as possible without going to a fully water cooled system. I have been looking at the Gigabyte Aorus RTX 2080 ti xTreme Waterforce 11G AIO but at £1600 its a small car and I am struggling with that in my head even though it is within my budget. Air cooled seems to be the more appropriate option but I am concerned about noise levels. Can anyone provide advice on what may be the best card for this while keeping noise levels low? A lot of reviews point at the Asus Strix 2080 ti OC for being a good card but it runs hot and my concern is that will bring fan noise. The Gigabyte Aorus equivalent is said to have issues pushing its hot air back in to the case which again would increase temperatures and therefore fan noise. So I'm stuck with which way to go. Any advice appreciated here? Any reviews showing Dba output or videos would be great too!
After this I am down to memory and peripheral items which I think I have a grasp of but will come back.
Thanks in advance
- 1 x Gigabyte Z390 Aorus Master Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £274.99
- 1 x be quiet! Silent Loop Superior Liquid CPU Cooler - 360mm= £149.99
- 1 x be quiet! Dark Base Pro 900 Rev.2 Full Tower Gaming Case - Orange= £249.95
Total: £689.03 (includes shipping: £14.10)
Thanks in advance
