- 3 Feb 2012
- Bath
My goodness, that 680X is gorgeous. Seriously tempted.
Trying the 680x against an evolv x
let us know how you get on! in theory 2 140mm fans at the bottom of the case should blow away the Evolv X for airflow
Pun Intended?![]()
I meant the whole "Blow the Evolv X away for airflow".just how the case should have been set up haha . they should have pre-installed the rear fan at the bottom personally !
I do get what you mean though. We have a 680X in the office and I personally like it. Strangely enough, it's one of those cases that looks a lot better in white than it does in black. Would have been nice to see a Gunmetal Grey though as I have a particular soft spot for Grey cases...
As far as I am aware, it has been done for contrast. The PCI-E Slot covers on the rear panel are also black. Similar to how Fractal Design have Black cases with white contrasting internals.does the white version have the White LL ? guessing from Product pictures its the Black versions... why a PM would allow this to roll out![]()
do it ! haha
I had the Evolv.... DONT DO IT!!!!! a gimp has more breathing space with its mask sealed!!!!
has to run 3x £20 fans and god aweful ekwb se360 to cool an i7 8700k .
if you grab the 280x and stick two fans at the bottom, you'd have massive positive pressure , less dust and will expel hot air nicely out the top and rear
its also quite tall due to being able to house 40mm rads up top and psu at the bottom. glass is quite dark to
Think I have the case, one in sig, the airflow seems perfectly fine, temps are great.
just to add to cents , the 680x is an awful chassis for airflow despite its marketing the old style 540 was better in this regard. generally a poor thought out case
i BEG YOUR PARDON![]()
