Internet download speeds
27 Mar 2016
Bristolian living in Swindon
Hi all
Ive got the PC running and have got Steam loaded onto it but heres where the terrible bit is....
PUBG is apparently going to take 3 days to download... surely thats not to do with my Sky internet speeds, Could it be the fact i only have a little TP Link dongle that cost me £10 thats slowing the download?
How fast is this dongle? Have you checked speedtest to see what speeds you are getting?
Its the N300 which does upto 300mbps, i have no idea if thats good :p
Just done a speedtest, the results are:
Download: 0.64mbps
Upload: 0.14mbps
Ping: 227.20ms
Jitter: 173.46ms
Probably terrible :p anyway to speed up would be appraciated please :p
At a download speed of under 1Mbps I'm surprised its only taking 3 days!
What speeds do you usually get?
Not to sure on the usual speeds but it's never been this bad... We used to have Virgin media now we have sky and its balls it all right up.... Also a quick question... I just restarted the PC and it came up error but when I went into the bios from error screen and clicked the relevant SSD it went onto my desktop.. Very odd but do you know what it could be
Download: 0.64mbps
Upload: 0.14mbps
Ping: 227.20ms
Jitter: 173.46ms
Definitely a massive problem here! I'm surprised you can browse the internet with that connection. :)
My best guess would be your distance/reception to the router is the problem.
How far are you from the router and what is the connection strength like?
Download: 0.64mbps
Upload: 0.14mbps
Ping: 227.20ms
Jitter: 173.46ms
LOL you should move to ISDN it might be quicker ;)
Something isn't right there, that is dog slow!
connection shows full strength and the router is in the living room downstairs directly below where I have the pc
Get a long ethernet cable and use that for downloading. If it's still slow then it's your Internet speed, phone them up or swap ISPs.
It sounds like there is some hardware issues going on there too.
I'm not sure what router/modem Sky uses. But try logging in to that and finding what your speeds are.
They usually say attainable speed, then your sync speed, the sync speed is usually less than the attainable speed.
This will tell us if the problem is your internet speed connection or your computer.
No this is the only Pc we have... We had another PC which I sold recently in the exact place the new PC is and had no issues like this.. Very odd
Can you do speedtest on your phone while standing close to the router.?
You can also check your connection stats by going to 192.168.0.1 then maintenance and log in with admin/sky
there you should find connection speed .
just ran a speed test on the phone...
Ping: 1ms
download: 6.20mbps
upload: 134.88kbps
some big differences there
Oh the memories of my smugness of having 2 64Kb digital lines running on dial up whilst all my friends had crappy analogue 56k modems on a single line. I was king of the hill. Then the phone bill came in :(
Part of your problem lie with moving from VM with their better FTTP w/Coax to the Router infrastructure (albeit in some locations oversubscribed), to a bog standard ADSL line with Sky - quite a large downgrade imo. I would guess at a cost saving exercise?
That aside, basic TShoot steps apply.
1) Sync rate check from within the Sky Router and record the sync speed seen.
2) Take everything off of the Router and cable 1 Laptop into the Router and run a few Speed tests (3 or 4 over a 20 minute period to get an average throughput) if not too dissimilar to the sync rate based on the average then you know the throughput is OK.
3) Add devices back on the Router 1 by 1 and run a test as you go ensuring the speeds remain fairly consistent.
If you encounter an issue and speeds collapse when you've added a device it could be an issue there.
I'm also suspect about the Latency PING response. On one test further up the thread you advised 135kbps upload throughput which is quite concerning as this could be congested and is causing the high latency. Have you got any P2P/FileShare/FTP running in the background?
Shawrey
