Best asking in the customer service area as most of this forum is frequented by more enthusiasts rather than OcUK staffAre there any more dimension drawings there as I have a complicated case design that I need to get my head around.
I found this from Mr Monsoon on his you tube demo.
http://geno.boxgods.com/MMRS-DIMS.jpg
What is not shown is the depth of the tube into an end cap, and the total length of a D5 mount with a motor on it and cover.
I have preliminary designed my reservoir but there are lots of parts that you do not stock, or no longer stock.
What also puzzles me is the fill port caps are not shown, yet you have lots of fill ports in stock. How do you expect to sell the fill ports if you don't have the caps to install them on.
If I made out a list of monsoon parts that you do not show would you be able to supply them on you next intake of Monsoon stock or are you phasing out Monsoon products.
I have an MMRS at home so could help with some measurements later.
Apologies, I've just had to dust-cover my entire studio for builders, so finding that reservoir might be a bit tricky. I found this on a review site:Hi LuckyBenski, thanks for your reply, I would greatly appreciate if you could measure the length of a tube when it is fitted that would give me the depth of the seat, so for example if a 100 mm tube left 90 mm exposed there would be a recess of 5 mm in an end cap, from that it is easy to work out total dimensions. Also the other dimension that I would like is the length of end cap with a D5 pump fitted and a standard cover. I know the cover extension adds 10 mm.
Many thanks
Whiskers
The actual length of the tube is ~8mm longer than the listed length which is a nominal length, so the 150mm tube we are using measured in with a length of 158mm. As mentioned previously the length is measured from the visible acrylic tube seen when fully assembled. This means ~4mm at each end of the tube is unseen when inserted into the end caps or couplers.
(From https://www.xtremerigs.net/2016/06/15/monsoon-mmrs-reservoird5-top-combo-review/)
This might be enough for you to work with - I'd suggest starting a thread in the watercooling subforum if you need more help.
Only place I've seen them is a retailer in the USA but can't link to them as it's a competitor to OCUKHi,
I would be interested on MMRS reservoir-d5 pump combo. Is there any white top caps and d5 pump tops available?
Meaning two last items on message #15
Hi,
Thanks for that, there are parts that I want that are not available from OCuk and I found them on Amazon US, looks like that will be the route for me to take. The postage from the Florida based PC Company is exorbitant to say the least.I was searching whole yesterday those parts. I could not find anywhere in Europe, so I actually ordered these from Amazon (US). The rest of MMRS components I ordered here.
