- 23 Mar 2011
Hey all! Repainting my son's room this weekend. It was the first room I ever painted and you can tell as the cutting in to the ceiling is just awful!
So with that in mind I intend on now repainting the ceiling to fix that, then move on to the walls.
Never done a ceiling before but imagine it's straight forward. I guess I can actually put a strip of ceiling paint on the wall where they meet as I'll the be painting over this when doing the walls? Or is there a "best" way?
Then when it comes to do the walls, I'll probably put tape on the ceiling to prevent a bad cut in like last time. What tape should I be using? I used green frog in the past and it tends to peel some away (this could be down to the this layer of paint the housing developers used though?)
Thanks! Sorry it's a bit basic, any other tips welcome. My "Skills" got better after and subsequent jobs have much better lines
I was thinking tape to be better safe than sorry really
this pretty much sums up how I did subsequent rooms. It's straight forward for sure, I just wanted to see what was vest relating to ceilings as this is a first for that
I remember hitting the ceiling with the roller once when I got a bit too into it
