ah right, so intel may be best for me at the moment?Intel has lead at 1080p which is a bit of an expensive pain at the moment .
darn thought I was finally ready to try another build, so close
darn thought I was finally ready to try another build, so close![]()
I'd go ryzen 2700x (look for prices and x470 flagship board to allow for ryzen 4000 in a few years ) .
If pure gaming with 144hz +1080p screen with 2070+ card Then intel 9700 . If going 1440p and chasing frames then intel again .
If you were going to record/ stream and then edit videos with 2080ti the .would go 9900k .
Any streamers that I do watch, are running Intel's or ryzen flagship with dual set ups , personally can't stand to watch basic streaming .
If you can grab a ryzen 2700x and push 2080... Then be crazy not to. Would upscale to 1440p in-game on your 1080p monitor to give ryzen some breathing space and keep quality high, threads of ryzen will handle the encoding .
You can see why Nvidia is now pushing card with Encoding...
All this back and forth between intel and AMD.. they are cutting it out. Spend more on the GPU with them for frames and recording and basic ryzen and intel 6 core for gaming... Smart.. and Radeon is following suit
*** And streaming at 4k... Headache, but pretty if you got dual system packing flagship GPU and CPUs
Looks good, gigabyte has the only UK RMA with the boards, if you can't push the x470 Aorus 7 then X470 Carbon. Miss out on the B450 version as bigger brother has one more and will go further with future ryzen chips .
B450 carbon has 4 phases (two lo two high ), x470 carbon had 5 phases of the same type. Aorus 7 has 10 phases that are integrated (combines high and low MOSFET into single package for better performance )
https://www.tomshardware.com/news/gigabyte-layoffs-motherboard-sales-decline-2019,38543.htmlGigabyte might pass out some pink slips in the coming months. According to a report from DigiTimes today, the company is planning to lay off some of its workforce, mostly from its motherboard business, as the segment’s dwindling sales numbers are expected to continue declining into 2019.
very different from their z390 count and design
Just waiting for payday so I can get this ordered, might have a look to see if I can find any parts for a little cost saving tooOk so here we go, this could be it?
I'm sure I can push it for the motherboard
My basket at Overclockers UK:
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Red (CMK16GX4M2B3000= £98.99
- 1 x Gigabyte X470 Aorus Gaming 7 Wifi AMD X470 (Socket AM4) DDR4 ATX Motherboard= £239.99
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
- 1 x Gigabyte UD Pro 512GB SSD 2.5" SATA 6Gbps Toshiba 3D NAND Solid State Drive= £59.99
- 1 x Cryorig H7 Plus CPU Heatsink with 2 x 120mm Fans= £41.99
- 1 x CoolerMaster MasterBox MB511 RGB Midi Tower Case - Black Tempered Glass= £69.95
- 1 x Gigabyte GeForce RTX 2070 WindForce 8192MB PCI-Express Graphics Card= £479.99
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £289.99
Can't wait to get back into pc gaming!
I know this is going to increase my price further (never mind) but do you have any good recommendations for a HDD?Shopping from another site it's £1320 . Using g parts from both it and OCUK is £1287![]()
One more question would this build let me stream 4k from a ps4?? As the Pc usnt running a game at the same time? Would use an Elgato for that
Brilliant thank you!Yes, capture card . Need 4k version of your using PS4 Pro and want to record higher then 60hz 1080p or 4k
With the Ryzen 3000 launching soo do you recommend waiting to see if I can improve this build?
