Slow read/write Samsung 970 evo nvme
30 Oct 2014
Norfolk
I won an auction off the bay for a 970 evo 1tb nvme drive, so I wanted to make sure It's genuine etc, and ran a CrystalDiskMark
seq Q32T1, read speed is 830.6 and write is 787.5, which is way below the advertised... Is there something I've done wrong or could it be faulty? The drive is new and was sealed
On one post...I found this.
The Sequential scores are indicative of the drive being run with 2 PCIE lanes from the motherboard and CPU instead of 4 for maximum performance. It's a hardware issue and not a fault of the drive.
Can anyone explain?
Hi Lawrence,
Which PCIe slot have you got the 970 evo plugged into?
Regds, JR
That sounds as if you have it plugged into an M2 NVMe slot. When I had a quick look at the user manual for the Gigabyte Z97 G1 Sniper it didn't seem to have an M2 NVMe slot, so I'm puzzled. I assumed therefore that you were using a bridge card (M2 to PCIe slot). Am I making a mistake?
Regds, JR
Regds, JR
http://tinyimg.io/i/X3t9OTs.png
It's plugged into the M2 slot, for clarification, motherboard is ga-z97x-gaming 5.
Is it not the right slot for it to reach the speeds and need a different motherboard?
Z97 chipset boards only have 2 PCIe lanes, to run a 970 EVO at full speed you need 4 PCIe 3.0 lanes.
You might be able to get better performance if you get an adapter and install it in the second x16 slot but it will reduce the GPU to x8 lanes instead of x16.
I see, thanks, I'm trying to look at motherboards that mention 4 PCIe 3.0 lanes, and can't seem to find/or looking at the wrong spec, could you throw me an sxample please
You would need to upgrade your CPU to at least an Intel Skylake or AMD Ryzen. Unfortunately Intel Haswell chipsets don't have enough lanes.
Smoogels is right you can get an adapter card. In practice I doubt you will sense any change from dropping the video card to 8 lanes.
I'm confused, why would I need to upgrade my CPU, couldn't I just get a motherboard that supports 3.0?
If I were to get an adapter card, it may reach its potential? Or are you saying it won't change a thing?
You can put an M2 to PCIe adapter card into your second x16 slot, which supports 8 lanes. This would reach the full potential of the 970 EVO. However as Smoogel has said, the consequence of using the second x16 slot is that the first x16 slot (where your probably have a video card) will drop from supporting 16 lanes to 8. What I am adding to this is that I doubt you will notice any change in performance in your video card.
Thanks a lot for explaining, appreciate the replies, I shall get an adapter then!
