- 18 Feb 2007
- London
A good wireless thermometer that can do both food and grill temps and an instant read thermometer.Just a heads up you can buy the Weber Master Touch in grey from go outdoors for £135 - price matched from B&Q (hotukdeals)
Going to order the chimney, lump wood, briquettes, fire lighters, metal brush.
Any other tips or must buys?
If you’re wanting to do some low and slow cooking you should look into some sort of heat deflector too, I’m not sure what people use on the Weber grills.
Do you guys use water pans when smoking?
That's just given me a crazy idea. I use sand in my vertical smoker for temp stability. If I 'bake' the sand in my oven at 115C and put it in the smoker at the same time as I put the coals in, that should make getting up to temperature and lessen the fluctuations after putting the meat in shouldn't it. Shame I'll not be cooking this weekend.I used to but I switched to using a large terracotta saucer. The temps stay just as stable but I don't burn anywhere near as much fuel as I did when using water.
Picked up an Inkbird IBT-4XS smart thermometer, looking forward to trying out, got cheesed off running outside to check the previous 2 probe digital one.
I have the IBT-2X and it's a great little unit. The free app that links to it is pretty decent as well, easy to setup and use which was nice. The Bluetooth connection isn't the strongest (nowhere near the range they claim in my experience) however your's is a different, more expensive and newer unit to mine so will probably be better! Be interested to hear how you get on with it.
Has anyone had any experience with the Traeger grills/smokers? I admit that I have only scimmed through a few of the recent pages and intend to read the lot but felt it would save time to just ask.
*Edit* Sorry my bad, Didn't anticipate the search function on the forums working so well. Would still be interested to hear what any Traeger owners think about the products.
Bought a new bbq a beast
