I'd be interested in this too - as we're viewing on Tuesday before completion on Thursday
I've read that you should check;
- all the doors; open and close
- all the windows; open and close
- all the appliances; oven, fridge, dishwasher, washing machine
- taps; check they run hot/cold
- showers; run hot/cold
- toilets; use cold water! check boiler doesn't kick in
- all the sockets
- all the lights; inside and outside
Any other recommendations?
Got back an hour ago from viewing the house again, i will list below what i checked.
As i have built in appliances i checked:
Fridge/Freezer, Dishwasher, Tumble Dryer, Washing Machine, Oven, Microwave, Gas Hob, checked they all worked, checked the oven got hot, checked the hob ignited and the fridge was cold and the freezer.
Checked the kitchen tap went hot and went cold, checked the plug hole drained the water away.
Checked all the kitchen switches and plugs, opened the drawers and cupboards to make sure no creaking noises or no doors hanging loosely, checked all door handles were tight.
Moved onto the living room, i checked all the plugs were ok, checked the access for Virgin, Sky etc, made sure the windows open and shut flush and the locks work.
Fuse box was checked and ok, light switches and power sockets.
Checked the bathroom for leaks, hot water and cold.
Checked the boiler, starts up fine and also checked the paperwork for warranty and last service.
Front and back door locks were checked, also made sure both doors shut flush and don't open with any resistance.
That's pretty much it, may seem over the top to most experienced buyers but as this is my first home, i wanted to be over cautious.
