Hi guys
Just starting a new build, I have all the hardware listed below, looking to water-cool CPU and also the 2080TI (water block ordered for the 2080TI though I do not have it yet) Looking to fit the 420mm radiator in the top of the case and the 360mm in the front its more the order that the items are connected, I will be using PTEG tubing.
Asus Maximus Hero XI
Intel 9700K
EK-Velocity sTR4 D-RGB - Nickel + Acetal - Water Block
Corsair DDR4 3200MHZ RGB 2 x 16GB = 32GB
EVGA 2080 TI Ultra FTW
Samsung 512GB 860 PRO SSD 2.5" SATA
Samsung 960 PRO 500mb M.2
Asus PG348Q ROG Swift 34" 3440x1440 IPS G-Sync 100Hz
EVGA SuperNova G2 1000W PSU
Case EVGA DG-87 (Bought the case form Ebay)
EK-CoolStream PE 360 Radiator
Alpha Cool NexXxos XT45 420mm Radiator
Aqua Computer D5 RGB Pump & Top
EK-RES X3 250 RGB Reservoir
PSU and the water block for the CPU fitted and the motherboard attached to the case, any advice appreciated.
Intel 9700K
