Status
Not open for further replies.
20 May 2010
Englishman in the USA
Guys how do you wash your microfiber clothes. Hand wash or machine? Also would you wash each one after single use?
Washing machine with uncented detergent with no added bleach or anything like that. Do it after every time they're used. Mitt, cloths and towels get washed every time. I don't usually wash the things used on the wheels with the other things though.
3 Jun 2012
Any MF used for wax I soak in a sink with washing up liquid. Then in the wash with Costco cheap detergent.
Don't use fabric softener, it seems to stop fluffy MF from soaking up water like it did before
FTM
FTM
10 Dec 2003
South Shields
yeah a non bio with no softener is what is usually recomended
a number of suppliers of car cleaning liquids also offer up their own microfibre cleaning stuff as well now..but I suspect its just a non bio detergent
1 Mar 2010
why non-bio ? you want to shift any oil/petrolium based stuff , have always used bio on eg. autoglymresinpolish cloths.
different tack - I've always bucket/hand-washed foam mop pads ... don't know what a machine would do to them
Man of Honour
21 Nov 2004
Forgot how fun snow foaming a car is and how much easier it is then to wash. Have some autoglym shampoo to use, it worked well in the lance :p. Used it neat - foam everywhere :D
Going to buy some polar seal next - that stuff looks fab. Will get another lance for it.
Nilfisk C110 on offer for 59.99 at Amazon at the moment.
https://www.amazon.co.uk/dp/B01MTZWJWA
Mine is still going strong years later. Survived the winter in the shed too.
Man of Honour
21 Nov 2004
I take it the Nilfisk Snow foam is crap?
I don’t think I ever tried it. I only ever use the autoglym snow foam and it works well. Don’t expect snow foam to work wonders. It removes some grime, but you still need to hand wash. It reduces the abrasive materials left on the paint at least.
I like autoglyms three step pressure wash approach. Just need to try the polar seal.
Status
