Thought it was the 22nd today, doh.. Ok so the day after tomorrow
Quick someone do an intel "day after tomorrow" mash up
Well exactly. That's my only concern too. That Ryzen can't hit the clocks so they start throwing 16 core, essentially useless (for gamers) parts at us to try and stay relevant.Unsure I actually need 12 cores.....8 seems fine to me.
Its all about the clock speed increases and any IPC improvements now.
I got my head bitten off for asking that question.What's the relevance of tomorrow?
Have a read of this
https://en.m.wikipedia.org/wiki/Dining_philosophers_problem
Coding for more cores is not as easy - devs can do it, the question is who wants to put the effort in.
Another good example: imagine you’re in a car with several people. One person controls the accelerator, one person controls the brakes. One controls the steering wheel. One controls the indicators. One controls the clutch and one controls the gear lever. Now try driving to work - that is multithreaded applications
Also game Devs are really going to have to knuckle down and start building games that use as many cores as are available. I don't see why they can't do this. Because cores are the future not clocks
As much as i like HWU's videos, that test is a bit misleading...ideally the 9400f should be paired with a b360/b365 board with max 2666 ram (which is what most budget builds will be)
And the 2600x should be paired with 3000/3200 ram +/- overclock, this will give the fairest comparison as to what a budget gamer will most likely use.
Given that the 2600x will perform better with expensive 3400mhz ram, in comparison to the 9400f, biases the benchmarks towards AMD...of course, value-wise, ryzen 5 wins hands down.
The only other factor I can think of is that the b360 board may require a bios update before being able to run the 9400f, and there isn't a lot of choice of b365 boards around.
My basket at Overclockers UK:
Total: £395.46 (includes shipping: £10.50)
- 1 x Intel Core i5-9400F 2.90GHz (Coffee Lake) Socket LGA1151 Processor - Retail= £169.99
- 1 x Gigabyte Z390 UD Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £119.99
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Black (CMK16GX4M2D30= £79.99
- 1 x Cryorig M9I Single Tower Heatsink for Intel= £14.99
Total: £358.46 (includes shipping: £10.50)
- 1 x Asrock B360 Pro4 Intel B360 (Socket 1151) DDR4 ATX Motherboard= £82.99
Total: £359.47 (includes shipping: £10.50)
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £169.99
- 1 x MSI B450M Mortar (Socket AM4) DDR4 mATX Motherboard= £88.99
- 1 x Kingston HyperX Predator 16GB (2x8GB) DDR4 PC4-25600C16 3333MHz Dual Channel Kit (HX433C16PB3K2/16)= £89.99
I've not added a separate heatsink (as always ocuk ryzen prices are higher than its competitors - so consider it as an aftermarket heatsink already added on)
He put the 9400F on a Z390 and overclocked the ram to 3400Mhz, the same as the 2600X, as well as stock on both.
He tested for every contingency
not quite. have a look again.
9400f + 3400mhz ram
9400f + 2666mhz ram
2600x stock + 3400mhz ram
2600x @ 4.2 + 3400mhz ram
would've been nice to see a 2600x stock + 3000mhz ram though - which is what most non-enthusiasts will run these platforms at. i know this is an enthusiast forum and we like to overclock...but in the grand scheme of things, we are but a very tiny minority.
Thing is, not all ryzen chips will be able to run 3400mhz stable.
(£120 for 3600mhz ram cheapest and downclock, £80 for 3000mhz ram).
That's still £40 extra for a "budget" build is a large % of the whole budget
I skimmed through the results and its possible I have missed the one humbug reffered to, but the only game I noticed with noticeably lower min's on the 9400F was the new BF game.
However that was due to the lower ram speed it was on 2666mhz mode, at 3400 it was close to the ryzen.
Also he was using stock turbo which in multi core games on intel will run slower than the ryzen, definitely slower than the o/c 4.2 graph. So even when the 9400f was slower to just say "lack of threads" is not right in my view.
The 2600x is a nice chip, but I think humbug was been a bit misleading, it got my attention since I own a 6 core non HTT chip.
I agree with tamzy on the ram speed, this is the same problem that was raised when intel got that company to do 9900k reviews, all the youtube reviewers were claiming that fast ram should be used as else ryzen is crippled, but that should be a "tough luck" situation. I wouldnt necessarily say only use jedec ram in the thing, but I think 3400mhz ram is "too premium" for most people buying a 9400f or 2600x.
What was odd to me is why did he have a 2666 vs 3400 for the 9400f but just 2 3400 results for the 2600x?
If you're going to do that here's some 3333Mhz here for £90 https://www.overclockers.co.uk/king...l-channel-kit-hx433c16pb3k2-16-my-26n-ks.html
Run them at 3200Mhz, tighten up the timings a little, the 200Mhz isn't going to make much difference
Already thought of that when I did the example specs
