Your right but it’s not many it’s most.Because you're one of those people that benefit from mainly single threaded performance, of which there are many. There are also many that benefit from higher core count. The key is to work out which one you are before spending hundreds changing your system.
Going from X58 Xeon to say an R5 2600(X) would result in a pretty big IPC jump, lower power usage, and a bunch of new features, but the same number of cores and similar clock speeds. Definitely looking forward to Ryzen 3000.I'm in the same boat as Easyrider, when i was buying my pc, best was intel, bought i7 920, that machine lasted far too many years, but that's why i was buying x58 in the first place, needed logelivity, as it served my right. Then after many years upgraded my gpu, and was some problems with mobo not having eufi bios. This time round i got Ryzen, this wasn't an upgrade it was a side step. But machine is doing a very good job, now i only swap my cpu when new ones comes out. Happy to be in AMD boat, and hopefully it wont disappoint. As i never liked Intel, but x58 did a grate job, i take my hat off for them.
I should have gone for an I7 9700k or 8700k which would have given me extra cores and maintained clock speed. Win win.. Sigh...
I can sit and hope with everyone else that Zen 2 will at least match intel in clockspeed and drop one in (which I’m happy to do) but even if it does it’s no guarantee that it will work better than intel as most software is optimised for Intel
All while getting nearly double the cinebench score.
Bit of everything. Photoshop. Video editing, gaming.and if all you do all day is bench cinebench than that was 100% the right move.
now over in the real world what do you use your system for?
I’m using a Dark rock pro 3 air cooler and my 5ghz delidded i7 7700k was pretty silent but at stock my 2700x is quieter, if I oc it even a tiny bit it gets noisy but perform ace from an oc is negligible so it’s not really worth it.Ive just switched from 6700k @ 4.6ghz to a 2700 @ 4ghz.
Couldnt be happier. Its my first AMD CPU since an athlonx4.
Compared to the 6700k it is considerably cooler and therefore quiet!
I responded, Xeons are found cheap second hand or when EOL, not at the time of launch. Intel charged a premium for extra cores rather than slowly introducing them into consumer products at an affordable price. Second hand vs new products years later is a different issue altogether and yes, there Xeons have plenty of merit and good prices but that's not what I'm getting at.
off topic but I still have one of those in my windows 98 machineI plan to switch from an I7 5820K to, if the rumours are true, a 12 core highly clocked Ryzen 7 3700X. This will be my first AMD CPU since the venerable AMD Athlon 'Thunderbird' 1GHz and I'm looking forward to it. I hated the stagnation and lack of progress from Intel until Ryzen showed up, including their use of cheap TIM on their enthusiast parts.
Wow, it's great it is still going!off topic but I still have one of those in my windows 98 machine![]()
Thank you to all the loyal AMD fans who bought FX chips and AMD GPUs. Otherwise AMD wouldn't have had enough R&D for Ryzen and Intel would still be pushing 4 cores on most of their line up.
.Yes.As my PC is my hobby (I cannot claim I am an enthusiast) nothing is better than competition in the marketplace to drive prices down.
I have not bothered with AMD since their AMD 64 x2 days.
I really hope AMD's 3rd gen Ryzen performs well, because I want one.
I have sold my R9 290 on the MM and now have a 980Ti. It is sad when a 4 year old GPU is an upgrade. Can't justify the £££ on a newer one!Yes.
Please let the games begin. AMD take em to the cleaners and shake up the consumer CPU space! (And if you have time something decent for the GPU high end would be awesome kthxbye).
.I have sold my R9 290 on the MM and now have a 980Ti. It is sad when a 4 year old GPU is an upgrade. Can't justify the £££ on a newer one!
Back on topic - I look forward to AMD's mid-year CPU refresh.
Not really sad as the 980Ti card is still a great GPU, even at 1440p. It would definitely benefit from more than a 4 core 4 thread Ivybridge i5 at 4.4Ghz.I have sold my R9 290 on the MM and now have a 980Ti. It is sad when a 4 year old GPU is an upgrade. Can't justify the £££ on a newer one!
