Engine bay switch live feed?
24 Dec 2010
Anyone done this before I get the multimeter out?
Any inspiring ideas on a suitable engine bay switch live feed? No fuse box nearby, canbus wiring.
Windscreen washer motor maybe?
Ta.
2004 BMW 645.
Water temperature gauge.
I know I could probably tap into the fuses in the glove box but really want to run the feed through the firewall to keep it tidier.
Thanks.
Your BMW doesn’t have a temperature gauge? :confused:
Nope. In their wisdom they equipped it with an oil temperature gauge in a bid to give it a 'racy' feel. :rolleyes:
Stupidly, it can actually read the temperature but you can only display that in the dash by going through a stupid amount of faff each time.
Why do you even want to know the water temperature out of interest
Got a long-ish trip coming up, the cars old and the cooling systems on dinosaur Beemers isn't the greatest. Just want a bit of pre warning if it decides to toast itself, maybe save a head gasket. Just peace of mind really.
Autool X60 Car OBD Scanner Digital Meter Digital Turbo Boost Pressure Meter Overspeed Alarm Water Temperature Gauge Car Voltage Meter Time Display for 12V OBD Standard EU/US Vehicles https://www.amazon.co.uk/dp/B07BF568WW/ref=cm_sw_r_cp_api_i_by-ZCbH70VVCR
Can get things like this if you have an obd port
Yeah, just been looking. Found this one too, yours looks a tad better quality though!
https://www.amazon.co.uk/ACBungji-S...ocphy=1006803&hvtargid=pla-771978799607&psc=1
You could run the Torque app from Obd2 via Bluetooth, the Obd2 adapter is about £5 and the Torque app is about £4.
Wow, that's pretty comprehensive! I use the phone for sat nav and speed camera alerts though, will give that a good look though. Like the way the guy seems to know his stuff and is always developing the app. Cheers.
If your phone does multi screen you can split it 2 thirds nav and 1 third torque with 2 dials displaying.
Or just pair it with q tablet
