The Division 2 - March 2019
5 Nov 2014
Does anyone still have issues trying to play this game at night? Was on last night and a number of times it’s so dark in areas that I cannot make out anything or see properly at all. It’s getting really annoying now
30 Aug 2006
Managed to finish the last stronghold so I've now been introduced to the new factions and missions etc - chose sniper as my specialisation but it would appear the ammo is limited??
I know I should really listen to/read the info but how do you get ammo back?
Ammo is got from killing mobs in certain ways i.e. using your specialisation granade. It also seems to disappear when you leave the mission or something.
5 Nov 2014
Do you have neutral lighting enabled?
It was Off but tried either on or off which made no difference.
The issues are inside and outside and making it quite annoying to do invaded missions when I can’t see anything. Settings are all left on what the game set with just trying natural lighting on or off
3 Dec 2004
I'm WT1 I'm trying to get the chatter box.
1) how do I know what parts I have collected.
2) Does the blue print drop from any where else. As I can't redo the bank mission, that the guides say I need to do for the BP.
The parts show up in your resource tab as an exotic component. They will have specific name like 'SMG loaded canister' so you know what you're missing.
You should be able to rerun the missions as many time as you like?
11 Nov 2009
Edinburgh
So I have unlocked tier 3 and pretty much doing control points etc as I have no invaded missions waiting to be done.
I need to do these top progress.
  • Complete Potomac Event Center invaded mission
  • Complete Federal Emergency Bunker invaded mission
  • Attain a Gear Score of 375
Gear seems to be coming along nicely I am at 267 but I still have no idea why. Do I need to keep doing control points etc before these mission become available?
Edit, Seemingly all I needed to do was to attain the gear score for the stronghold to be available. And playing with my gear pushed me to 385.
5 Feb 2008
Not true, the parts are found in Hyena boxes. It's only the BP though which drops from the Bank HQ mission.
Kendra's Liberty Drops from Boss on Hard or above
Part 1: American History Museum
Part 2: Viewpoin Museum
Part 3: Space Administration HQ
The Lost Chatterbox - Drops from Hyena Caches
Part 1: Grand Washington Hotel - Loaded Canister
Part 2: Jefferson Trade Center By the end of the parking garage to the right - Creative Magazine
Part 3: Federal Triangles - Police Station - Modified Mods
Part 4: Bank Headquarters - Blueprint
Sweet Dreams DCD Headquarters
Pestilence - LMG Random drop in the Darkzones from blacktusks
Merciless - Rifle Drops from Boss on Hard or above Jeffersons Trade Center
11 Nov 2009
Edinburgh
There is a building that has a faction chest in it. This building far left of Constitution Ave NW and opposite the south end of 6th St NW with Driveway in front. According to a video the door is open except it is not?
Right bottom of map. The building has no name though you can get into a small bit of it around the back but certainly not right into the building.
Any thoughts?
3 Dec 2004
So if I didn't get the BP, I will never get it. That's silly.
You will be able to get it, you can play the mission again,
The BP only drops once you have all the components, it doesn't drop at the end of the mission though. Theres a hidden button to press about half way through that gives you access to a hyena box which contains the BP.
Probably best to read a guide on how to get it as it's not straight forward
5 Mar 2010
Got a source on that?
Everything I've read says it drops from a Hyena boss on any difficulty. Few missions with Hyena bosses, but no one seems to have had one from a Hyena bounty.
5 Feb 2008
Myself got 3 of them and all from Jefferson.
Most others also got it from there.Sure,other sources as well- Hyena bosses etc,but those who want it running mostly Jefferson.
Not sure about any difficulty,as lower difficulty usually means lower %.
Challenge or Hard are my only options tbh.
Caporegime
17 Oct 2002
Lancs/London
It'll craft at 490 at WT5 I believe so you'd still need to upgrade to 500 if it bothers you. Need to be careful with that though, I rolled a 490 Nemesis that had higher damage than a 500 upgrade.
Caporegime
29 Aug 2007
Auckland
Question on drops when grouping up with other players - are the drops discrete to each player or are they viewable and shareable for all of the team? i.e. do we all see the same drop and if I pick it up, the rest of the team can't, or do we each see only our own drops? I've got a sneaking suspicion I've been hovering up loot without checking if anyone else needs it :/
