Does Windows 10 need a driver for NVME drives?
11 Jun 2004
Middlesex, London
Hi all,
So I finally got the following running.
MSI Z97 Gaming 5 motherboard with an ADATA SX6000 NVME M.2 on a PCI-E riser card.
Windows 10 has installed fine and everything works, but I’m not quite getting full speeds when doing a SSD benchmark test
....so my question was ...do I need to install a driver for the NVME drive.? Or something else?
Thx
Does this Help?
Thanks, so this means I should be getting full speed?
Looking at the board specs;
https://www.msi.com/Motherboard/Z97-GAMING-5/Specification
You have to sacrifice the GFX lane count down to 8X so the lanes can be shared to the other 2 large 16X connections. Assuming you've got it plugged into one of the remaining 16X slots then yes should be full speed.
The native M.2 slot on that board though isn't full speed so you won't see this level of performance I'm afraid.
