intel being intel. probably not.Will z390 boards get PCIE4 bios updates?
Huh, how would that occur? Intel do not have any PCI-E 4.0 capable CPU's, and when they do you can bet they won't work on a Z390/Z370 board.
I am doing nothing. The laptop is literally idle with its fans going constantly, I guess they ddin't think to put a zero-RPM mode in it but the point is that small fans are always annoying, unless they're programmed to not spin up except in a few circumstances where they're actually needed.Sorry to hear this. I don't think it's normal. What are you doing with the laptop to cause its fans to spin all the time? Normally, the fans begin to rotate when you load the CPU or GPU a lot.
For a comparison, my Acer Nitro 5 is perfect in this regard, I hear the fans maybe not more than 5 times a day, and they become audible for no more than 5-10 seconds.
Which is your laptop's brand and make? I would try to write to their support for new BIOS/firmware, and then RMA if not helps.
I hope that new law the US made,does not affect AMD since it has kind of screwed over Huawei and Google. It affects how much tech US and Chinese firm can transfer between each other,and AMD is involved in this:
https://en.wikipedia.org/wiki/AMD–Chinese_joint_venture
Chipset fans, etc. are usually always on rather than temperature or load controlled and often make a bad whining noiseone thing I do find with Windows 10 is that more often than not when I first turn on it is doing prep in the background for the next lot of updates or other background tasks (the anti-malware service likes to hog a lot of CPU time sometimes) which keeps fans working harder for longer on laptops, etc. (and impacts battery life) putting my main laptop back to Windows 7 it rarely even spins up the fan at idle versus 10 where it would take like 40 minutes of uptime before it was quiet at idle.
Windows 10 is terrible for spying and background tasks and servicehost updates, even when you tweak the registry and disable the tac-ons. I wouldn't be suprised if reviewers get affected by their benchmarks, unaware of the resources being run.
Hey, nothing fake about that box. That's a real box. It is, however, just a boxI call fake, we're going to need a picture of the opened box sans AS bag I'm afraid.![]()
Those and the indiscriminate updates against exploits like MDS. I love Win10, though. It's so stable.
