- 1 Dec 2015
***Tidy Up of the Thread. Below are the X570 Boards being released by Gigabyte for Aorus and Gigabyte brands. You'll find Product link pages, PR pictures and real life snaps along with board details and video breakdowns
X570 AORUS Xtreme is Gigabytes Flagship Board feature 16 phases at 70amps each! 14 x 70A = 980A cross the vCore and 2 x 70A = 140A for SoC
PWM controller 16 channels !
https://www.infineon.com/cms/en/product/promopages/Powering_Next_Gen_Processors/
https://www.gigabyte.com/Motherboard/X570-AORUS-XTREME-rev-10#kf
Xtreme at Computex 2019
Unboxing
Next In the line up is Mainstream Flagship;
X570 AORUS Master featuring 14 phase. As mentioned before, upgrade over the z390 Master.
Board uses IR 3556 , 12 X 50A = 600A across VCore , 2 x 50A for SoC
https://www.gigabyte.com/Motherboard/X570-AORUS-MASTER-rev-10#kf
Master pictured at Computex 2019
Next up the running is the X570 Aorus Ultra featuring 14 Phases.
Unlike the Master, the Ultra uses the slightly less power IR3553 40A integrated mosfets . 12 For the VCore and 2 PPak Integrated Mosfet for the SoC.
Also unlike the Master the Boards uses 6 doublers as the Ultra features an 8 Channel PWM, the Master and Xtreme utilise a 16 Channel Controller
The Ultra features a 8+4 pin set up for powering the AM4 socket, Master and Xtreme feature dual 8 pins . All 4 boards including the Pro would handle a 16 core Ryzen 3950x easily enough, dual 8 pins allow more power for extreme overclocks and cleaner power deliver
https://www.gigabyte.com/uk/Motherboard/X570-AORUS-ULTRA-rev-10#kf
Buildzoid breakdown
Hot on the Heals of the Ultra is the X570 Aorus Pro (with or without AX Wifi )
Ultra Features the exact same VRM set up as the Ultra, main differences bar looks is the VRM cooling. Only one heatsink uses the finned design.
Also M.2 slots going from 3 to 2 as well as differing PCIe 4.0 lane distribution
https://www.gigabyte.com/uk/Motherboard/X570-AORUS-PRO-WIFI-rev-10#kf
Board at Computex 2019
Introducing Aorus's entry Board, The X570 AORUS Elite
Key differences over the Elite are a lower PCB layer count of 4 from the above 6/8.
There is only a single 8 Pin power plug - though still fine for 12 core at stock.
The VRM set up still features a 12+2 set up, and whilst using higher Amp mosfets (50A), they are slightly lower in quality (Run slightly hotter and lower thermal threshold)
https://www.gigabyte.com/uk/Motherboard/X570-AORUS-ELITE-rev-10#kf
Gigabyte's Entry board and following on the Huge performance of the Z390 UD over the Z370 Aorus boards is the Gigabyte X570 GAMING X
Featuring a 10+2 Phase design and 4 Layer PCB like the Elite , its one of the highest spec'd entry and sub $200 board there is!
Although at ONLY 10 Phases for the VCore, they are 60A units ! and integrated !!!
https://www.gigabyte.com/uk/Motherboard/X570-GAMING-X-rev-10#kf
Bring up the Rear is the outstanding X570I AORUS ITX board!
Featuring an 8 Layer PCB design ( same as the Xtreme) , which will allow for some huge RAM overclocks as well as it being a Two Dimm design!
With space being prime and in short supply, the board features 6 leading Mosfets in the form of 70a TDP units for its VCore and 2 40a IR3533 for its SoC !
https://www.gigabyte.com/uk/Motherboard/X570-I-AORUS-PRO-WIFI-rev-10#kf
X570I AORUS ITX at Computex
vrm/pcb breakdown
Unboxing
X570 Phase Chart
X570 has an updated BIOS look , will be rolling out to older chipsets/intel at a later date
Recap on z390 naming and VRM
X399 Aorus Xtreme is 16 x60amp (TDA 21462) Phases
X299 Master is 12 x50amp ( IR 3556) Phases
Z390 Xtreme is 16 x60amp (TDA 21462) Phases
Z390 Master is 12 x40amp + 2 ( IR 3553) Phases
Z390 Ultra to Elite is 12 x50amp + 1 ( Sic634) Phases
X470 Aorus Gaming 7 is 10 x40amp ( IR 3553) +2 Phases
X470 Ultra is 4 x(1 hi 4C10N & 2 low 4C06N) +3 Phases
Infineon TDA21472 PowIRstage
- Supports AMD 3rd Gen Ryzen™/ 2nd Gen Ryzen™/ 2nd Gen Ryzen™ with Radeon™ Vega Graphics/ Ryzen™ with Radeon™ Vega Graphics Processors
- Dual Channel ECC/ Non-ECC Unbuffered DDR4, 4 DIMMs
- Direct 16 Phases Infineon Digital VRM Solution with 70A PowIRstage
- Thermal Reactive Armor Design with Fins-Array Heatsink, Direct Touch Heatpipe and NanoCarbon Baseplate
- Triple Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with Triple Thermal Guards
- Onboard Intel® WiFi 6 802.11ax 2T2R & BT 5 with 2X AORUS Antenna
- Rear 130dB SNR AMP-UP Audio with ALC1220-VB & ESS SABRE 9218 DAC with WIMA Audio Capacitors
- AQUANTIA® 10GbE BASE-T LAN + Intel® Gigabit LAN with cFosSpeed
- Exclusive RGB FAN COMMANDER for Professional Casemoders
- USB TurboCharger for Mobile Device Fast Charge Support
- RGB FUSION with Multi-Zone Addressable LED Light Show Design, Support Addressable LED & RGB LED Strips
- Smart Fan 5 Features Multiple Temperature Sensors , Hybrid Fan Headers with FAN STOP and Noise Detection
- Front & Rear USB 3.1 Gen 2 Type-C™ Headers
- Q-Flash Plus Update BIOS Without Installing CPU, Memory and Graphics Card
- CEC 2019 Ready, Save Power With a Simple Click
Unboxing
- Supports AMD 3rd Gen Ryzen™/ 2nd Gen Ryzen™/ Ryzen™ with Radeon™ Vega Graphics Processors
- Direct 14 Phases Infineon Digital VRM Solution with PowIRstage
- Advanced Thermal Design with Fins-Array Heatsink and Direct Touch Heatpipe
- Intel® WiFi 6 802.11ax 2T2R & BT 5
- Rear 125dB SNR AMP-UP Audio with ALC1220-VB & ESS SABRE 9118 DAC with WIMA Audio Capacitors
- Realtek® 2.5GbE + Intel® Gigabit LAN with cFosSpeed
- RGB FUSION 2.0 with Multi-Zone Addressable LED Light Show Design, Supports Addressable LED & RGB LED Strips
- Smart Fan 5 Features Multiple Temperature Sensors, Hybrid Fan Headers with FAN STOP and Noise Detection
- Front & Rear USB 3.1 Gen2 Type-C™ Headers
- Integrated Base Plate & I/O Shield Armor
- 12+2 Phases IR Digital VRM Solution with PowIRstage
- ALC1220-VB Enhance 114dB(Rear)/ 110dB(Front) SNR in Microphone with WIMA Audio Capacitors
- Intel® Gigabit LAN with cFosSpeed Internet Accelerator Networking
- Smart Fan 5 features Multiple Temperature Sensors, Hybrid Fan Headers with FAN STOP
- Front & Rear USB 3.1 Gen2 Type-C™ Header & HDMI 2.0 support
- Integrated I/O Shield Armor
- Q-Flash Plus update BIOS Without Installing CPU, Memory and Graphics card
Buildzoid breakdown
- Dual Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with Dual Thermal Guards
- Front & Rear USB 3.2 Gen2 Type-C™ Header & HDMI 2.0 support
- Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
- 12+2 Phases Digital VRM Solution with DrMOS
- Advanced Heatsink Design with Enlarge Heatsink
- Dual Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with Single Thermal Guard
- High Quality Audio Capacitors and Audio Noise Guard with LED Trace Path Lighting
- Front USB 3.1 Gen2 Type-C™ Header & HDMI 2.0 support
- 10+2 Phases Digital VRM Solution
- Advanced Thermal Design with Enlarge Heatsink
- Dual Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with one Thermal Guard
- High Quality Audio Capacitors and Audio Noise Guard for Ultimate Audio Quality
- GIGABYTE Gaming GbE LAN with Bandwidth Management
- Smart Fan 5 features Multiple Temperature Sensors and Hybrid Fan Headers with FAN STOP
- Integrated I/O Shield Armor & HDMI 2.0 support
- Q-Flash Plus update BIOS without installing CPU, Memory and Graphics card
- Dual Channel ECC/ Non-ECC Unbuffered DDR4, 2 DIMMs
- Direct 8 Phases IR Digital VRM Solution with PowIRstage
- Advanced Thermal Design with Extended & Multi-Layered Heatsink
- ALC1220-VB Enhance 114dB(Rear)/ 110dB(Front) SNR in Microphone with Nichicon Audio Capacitors
- Intel® GbE LAN with cFosSpeed Internet
- Rear USB 3.1 Gen2 Type-C™ Header & HDMI 2.0 support
vrm/pcb breakdown
Unboxing
X570 Phase Chart
