The hope is that it was set to 100% for demonstration purposes. As it's not short on ventilation - even if it is warm there...There ya go Motherboard Fan having a 'BLAST' :/
(Setup to the left mentions nothing about NVMe RAID etc...)
https://www.facebook.com/liptonTC/videos/vb.532325646907781/2091991384426750/?type=2&theater
He says in that video that this small fan is loudest part of this PC.What are you meant to garner from that video exactly.
Video of a fan running, so much background noise you can't even hear anything.
All I will say is damn X570 can hit some mental memory clocks, 4000+ is easy with decent memory.
The kit I mentioned (BLS2K8G4D30AESBK) will go to around 3600MHz, and some have pushed them well past 4000MHz. Your original query seemed to be about price/performance and it's not a straight line on a graph, there will always be a massive value increase going with a kit that can be overclocked well vs. paying over the odds for a pre-tested 4000MHz kit will show little value if you have to spend double or more to end up with the same result. 32GB kits are an unknown for me, on anything other than TR4, sorry.![]()
Conference centres are set to 20 degreesThe hope is that it was set to 100% for demonstration purposes. As it's not short on ventilation - even if it is warm there...
I don't really trust RAM overclocking tbh, i never had much luck with it. But i did find that kit you mentioned for about £66 which is dirt cheap for a 16gb 3000mhz kit. Too bad the price jumps quite a bit for the 32gb kit.The kit I mentioned (BLS2K8G4D30AESBK) will go to around 3600MHz, and some have pushed them well past 4000MHz.
Looking at the Gigabyte ITX x570 board it seems its confirmed to support 3200mhz ram, so I guess that is what I will be aiming to buy![]()
Gibbo pops in with 2 posts and everyone is scrabbling around buying overpriced high end RAM.Grab this kit
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
Anyone expecting RAM prices to go up again to coincide with Ryzen 3 demand? Wondering if I should buy now.
That has to be one of the worst articles I have seen yet.
talk about a confused list of "possibilities", they even state it is just a round-up from Reddit
Agreed! These points were my favorite from the muddled garbage...
5.0GHz is doable, but it’s a challenge
5GHz boost isn’t infeasible
5Ghz all core is pretty much a no-go.
Overclock for overclocking, Ryzen 3000 is still faster
Lol, the guy is a wizard salesman I'll give him that.![]()
4.8GHz is achievable on all cores
