Pic: Your desk...RIGHT NOW
Nearly finished! Couple more frames to go up (Infinity War and Captain America) then I think I’ll be done
Steedie. I can see you have the Alex drawers at one end. Are there drawers the other end, or is there just a leg holding the table up? How solid is the worktop? And how does it feel compared to a solid wood top?
I have a filing cabinet underneath but also two legs. The Karlby is a properly sturdy worktop, so the 186cm is more than happy to be supported at just either end. The longer one I think you’d want to support in the middle as well just to prevent any sag
I want the 186. So you think Alex drawers one end and two ikea legs the other would be solid enough?
Case has gone under the desk. Extra crispy clean now.
Recently switched back to my preferred OS, MacOS. Mac Mini + the new LG Ultrafine. The desk mat is so new it's still not flat at the edges! Also need hide the external SSD under the desk with a longer USB-C cable.
Ive got a Steelseries mat that’s curled at one corner and won’t go flat. I don’t think anything has ever bugged me as much.
Stick it to the underside of the desk with velcro. No need for a longer cable and even tidier.
I plan to stick some heavy books on the corners overnight, failing that a tea towel and the iron are going to have a go at it.
That was my first thought, but there is a big cable tidy cage under the desk which would be easier to just put it in there and run a longer cable.
A few changes. Mac mini I changed for a refreshed 2019 13" MacBook Pro. Speakers were moved on and I now have a HomePod. AirPods are now my daily headphones.
The pen has returned for @Steedie
