- 1 Jan 2003
- Derbyshire
I used to do a little bit of video editing years ago with Power Director. It did the job, but even making a short clip was a chore and took ages.
I've now started filming with a gopro, and I'm looking to edit the footage into small clips to upload for easy viewing. I paraglide and it looks great in 4K, but I only need clips of a few seconds each, and at quite specific moments, lots added up to make my film.
The thing is.... Unless I'm missing something, things haven't got any easier to do this, it still takes bloomin ages to find the small section of footage, then trim, add to time line, move on repeat.... get bored...give up etc..
I tried GoPro's own Quik, and my word what a mess! It seems to do its own thing and gives you very little freedom. But it has the right idea in terms of just grabbing a small bit and adding to your film. It only seems to do up to a minute, and 4k output is shocking quality (lot of users complaining about that)
What I would ideally like to do is just play back my recorded footage and while I'm watching press and hold a button (space bar for example) and that period/clip is added to the time line to make up my film automatically. So for example if I press 20 times, those 20 clips are added. Then I can move onto titles etc..
Is there such a thing?
Or can anyone recommend an easy method for short film making without it taking hours and hours, with high quality results.
Many Thanks.
Many Thanks.
