- 28 Feb 2012
- Chertsey
Hi guys,
Hope you can help me with this one,
I have an Aorus 2080ti Xtreme which i bought from overclockers about 8 months ago and its been working fine but just recently I noticed this weird and very annoying noise from my gfx card when playing games.
So the fans will at first speed up as per normal to lets say 80% (about 2200RPM) after some gameplay and then I think it might just be the middle fan or could be all three will just double the RPMs for about 3 seconds then come back down.. waits about 5 -8 seconds then back up again and repeats over and over.
The RPM reading when at 80% will be something like 2200 then ill watch it climb to 4000ish RPM before dropping. Even more odd is the Fan speed % doesn't change, just the RPMs.
I think it only started happening when I updated the BIOS from F2 to F3 so could be something there.
It is VERY loud (i can hear it over headphones just and people in the other room can hear it) when it does this and I can't control it at all.. For example I can manually place the fan at 100% fan speed (which is shows at 2800 rpm ish) then when playing it will shoot up to 4000ish every so often.. so running much higher than the 100% fan speed??
Is there anything I can do to sort this? Can I roll back the BIOS to F2 when things were easier? I don't want to have to RMA this over fan speeds but its so loud its not really useable and I paid nearly 1300 quid for it so anything I can do to sort it would be best.
Cheers for any help you can provide,
Matt
EDIT: Will also add if I set it to 100% while not in a game its fine and stays at constant RPM.. it only seems to do it when playing something.
Matt
