That Ryzen would be way better than that old Swiss cheese leaky Intel four thread CPU.I can buy a PC from another website for example, AMD Ryzen 2600 3.90ghz, RX570, 8GB ram, 1TB HDD, Windows 10 etc for £520
My decisions are generally based around, will it play GTA V.....yes, it will, OK that will do.
I can buy a PC from another website for example, AMD Ryzen 2600 3.90ghz, RX570, 8GB ram, 1TB HDD, Windows 10 etc for £520, but the whole thing is a minefield.
Next-gen consoles are simply going to completely curb stomp old quad cores in CPU power available for games.
Both will play GTA V, the first spec with RX 570 will make it a good experience. Tough game to run with settings that look decent.
Alright that price is good, to begin with. Ryzen 2600, RX 570 and 1TB HDD, so far so good. Here comes (some of) the minefield:
The 8GB RAM what speed is it and is it two 4GB sticks (dual channel - better for gaming) or a single 8GB stick?
Is the motherboard a solid B450 that will allow a cheap upgrade to a Ryzen 8-core (rather than buying new motherboard and CPU), or is it a cheapo A320 board? Does it have four memory slots (GTA+rest of the system will use slightly over 8GB memory if you have it, and benefits from it) so you can slap in two more sticks, or does it have two memory slots?
Is it a cheapo PSU? How much does it output on the +12v rail to be able to handle GPU upgrades?
Find out and weigh the pros and cons of cheaper stuff with Windows already installed, or spending a bit more for better components in some areas that will allow more cost-effective upgrading.
If upgrading is of no concern (it will be later on) then just get that £520 system.
Brilliant! Now I'm lost.....I haven't got a clue about any of this, maybe he should just stick with his PS4. Insert a disc and play.
Forget about the ram speed, its not important with a 500 quid system although it should have 2 x 4gb modules in it for dual channel access - something to ask.
Upgrading, your prob not going to do this... again 500quid system so dont waste your time worrying about it. 4 memory slots is nice if you want to take it to say 16gb in future and two are taken already.. but you could just opt for 16gb to start with for not a lot more.
cheepo psu, on a 500 quid system its not going to be epic. i wouldnt worry about it unless you want to chop out the video card for a much more powerful one at a later date.
Stuff you should be concerned about,
8 Gb of ram, if possible upgrade this to 16
no SSD, but a 1tb hard disk - imho not the way to go. 500gb ssd or even 256 which is prob enough will make the machine an awful lot faster.
get a 2600 6 core, nothing comes close rice/performance
a 570 is also near impossible to beat £ for punch.
You should - if you go into the build as informed as possible you shouldn't incur any major surprises and if you hit any problems there's usually someone lurking that will be able to talk you through any issues.Appreciate all the advice, just been watching YouTube videos, building the pc doesn't look too tricky....I may give it a go!!
(@Danny75 - how do we hide a certain horror thread?)
We could link to the last 3 pages - and tell him the previous pages were just preamble leading up to the final spec?lol I was thinking earlier, shall we show him hell first (the CPU saga) and heaven after (the easy pop in and running on all cylinders), or vice versa?
