Speakers too Loud with Preamp
28 Feb 2012
London, UK
Hi all,
I've got these active speakers that are hooked up to a preamp for volume control.
The problem is when the speakers are set at 0db, the preamp will max out the speakers with hardly any knob turn. Starting at 7 o'clock, it'll max out the speakers at around 10 o'clock. Hardly any room to adjust volume.
As soon as I take the speakers into -db, it distorts like crazy with the preamp.
Any solution to this?
20 Oct 2008
Why no details on the equipment? There's obviously a problem with the combination you've created. With the information provided, you can only expect generalisations and guesswork.
OP
28 Feb 2012
London, UK
I meant to include details but somehow forgot.
Schiit Bifrost Multibit -> JDS Labs OL Switcher -> iLoud Micro Monitors
20 Feb 2004
Hondon de las Nieves, Spain
What happens if you go from DAC direct to the speakers and use the volume control on your pc/speakers?
Does that make it manageable?
Otherwise try turning your pc down when using the amp and seeing if that gives you the control you're after.
EDIT - Also i'd have said that movement between 7oclock and 10 o clock was a reasonable amount of control? How jerky are your hands that you can't get to a decent level within those parameters? I don't think i've ever really gone past around 11 oclock on most of my amps as that's getting to silly volumes generally.
6 Sep 2016
Maybe some unusual voltage output, gain, or input level for 100% output on the speakers.
Or changing from one brand of power amp to another made massive difference to dB output at the speaker I had to cut levels down several dB go match the other amps.
