Sub £400 55" TVs
14 Feb 2007
Just finished decorating our spare room, to turn into a Cinema/xbox/chill out room.
I've not brought a TV for about 7 years. Any recommendations for a sub £400 55" TV.
Hisense looks to be good value, and there are also offerings from LG, Toshiba, Panasonic, Samsung and so on. Sound quality is not an issue, I will be using external speakers
14 Dec 2017
Aberdeenshire
A little smaller than you were after but I’m looking at this for my bedroom and it only
Comes in at £329
LG 49UK6300PLB 49" Smart 4K Ultra HD TV with HDR and Freeview Play
Caporegime
21 Jun 2006
It's not elitism; it's objectively true; at least in terms of buying new.
For that money, you'd do well with a used Pioneer plasma.
pioneer plasma? seriously. its 2019.
i wouldn't recommend anything less than 4K. even if it's a crap panel.
a pioneer could last 10 mins before it blows up. hardly worth risking £400 over
6 Sep 2016
Blu-ray is 1080p so what is the point of 4k? 4k movies are more expensive. Games consoles don't do true 4k a pc at 4k is going to be expensive.
And unless you get a huge screen then you won't tell difference between 1080 and 4k.
Plus.my pioneer plasma looks acr
1 Nov 2006
Scotland
Thanks for pointing out it is objectively true, I didn't realise that.
In most qualitative metrics which go into image quality: Black levels; contrast ratios; viewing angles; colour reproduction -all that good stuff- televisions coming under the £400 mark are going to be at the lower end of what is considered acceptable (if they can be considered acceptable). You largely get what you pay for.
5 Apr 2009
The Hisense H55A6200 reviews reasonably well for a cheap TV, recently got one at work and was pleasantly suprised at the quality for such a cheap bit of kit.
